Need help with RFM12b
pingza1990
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Oct 31, 2011 8:39 pm     Reply with quote
Hello everyone, this is my first post and I need a little help.
I'm making a project which involves two pics (16f886) and rfm12b.
Previously, I had to look at http://www.ccsinfo.com/forum/viewtopic.php?t=43563
Which I took extra, code to try.
TRANSMITTER CODE:
#include <16F886.h>
#device adc=8
#FUSES NOWDT, HS, NOPUT, NOPROTECT, NOBROWNOUT
///      RFM12B Driver                                ///
/// Functions:                                        ///
/// RFM12B_INIT(int type)                             ///
/// RFM12B_SEND(int buffer, int size)                 ///
/// RFM12B_RECEIVE(int buffer, int size)              ///
/// Updates:                                          ///
/// 09.01.2010 New Driver                             ///
/// Code was written by Severin Birrer                ///
/// More informations at www.blucorazon.ch            ///
/// PIN settings                                      ///
#define MOSI      PIN_C4 //cikis
#define MISO      PIN_C5
#define nSEL      PIN_C2
#define SCK       PIN_C3
#define IRQ       PIN_B0
#define LED       PIN_A0
/// Definitions                                       ///
#define MOSI_hi() output_high(MOSI)
#define MOSI_lo() output_low(MOSI)
#define nSEL_hi() output_high(nSEL)
#define nSEL_lo() output_low(nSEL)
#define SCK_hi()  output_high(SCK)
#define SCK_lo()  output_low(SCK)
#define in_MISO() input(MISO)
#define in_IRQ()  input(IRQ)
#define TX        1
#define RX        0
int16 RFM12B_READ_STATUS(void);
void RFM12B_FIFO_RESET(void);
/// RFM12B_PORT_INIT                                  ///
/// Function: Initalise ports to defined states       ///
void RFM12B_PORT_INIT(void)
    nSEL_hi();
    SCK_lo();
    MOSI_lo();
/// RFM12B_CMD                                        ///
/// Function: Sends command and receives data         ///
int16 RFM12B_CMD(int16 cmd)
    int i;
    int16 temp=0;
    SCK_lo();
    nSEL_lo();
    for(i=0;i<16;i++)
        if(cmd&0x8000)
            MOSI_hi();
            MOSI_lo();
        delay_us(5);
        SCK_hi();
        delay_us(5);
        temp<<=1;
        if(in_MISO())
            temp|=0x0001;
        SCK_lo();
        cmd<<=1;
    nSEL_hi();
    return(temp);
/// RFM12B_WAIT_READY                                 ///
/// Function: Wait for RFM12B to be ready (FFIT)      ///
int16 RFM12B_WAIT_READY(void)
    unsigned int16 data;
    nSEL_lo();//test
    while(!in_MISO())
        ;//test
/// RFM12B_READ                                       ///
/// Function: Wait and read a byte from FIFO          ///
int16 RFM12B_READ(void)
    int16 data;
    //  RFM12B_WAIT_READY();
    data = RFM12B_CMD(0xB000); // Read Data
    return (data&0x00FF);
/// RFM12B_WRITE                                      ///
/// Function: Write a byte                            ///
void RFM12B_WRITE(int abyte)
    RFM12B_CMD(0xB800 + abyte); // Write Data
/// RFM12B_INIT                                       ///
/// Function: Initalise as a sender or a receiver     ///
void RFM12B_INIT(int type)
    RFM12B_PORT_INIT();
    delay_ms(200);
    if (type)
        // Init Sender
        RFM12B_CMD(0x80A8); // Configuration Command  868MHz 12,pF Enable Tx Register
        // Init Receive
        RFM12B_CMD(0x8068); // Configuration Command  868MHz 12,5pF Enable Rx FIFO buffer
    // General Init
    RFM12B_CMD(0x82D8); // Power Management Command  Enable Crystal Osc.
    RFM12B_CMD(0xA640); // Frequency Command    Center Frequency 868.3200 MHz
    RFM12B_CMD(0xC647); // Datarate Command    Data Rate 4.789kbps
    RFM12B_CMD(0x94A5); // Receiver Control Command  VDI, Fast, 134kHz, Max, -73dBm
    RFM12B_CMD(0xC2EC); // Datafilter Command   Auto, Slow, Digital, 4
    RFM12B_CMD(0xCA8B); // FIFO / Reset Mode Command  8, 1 bytes, Synchrone, Low, FIFO Fill Enabled
    RFM12B_CMD(0xCED4); // Synchron Pattern Command  Synchron byte(LSB) D4
    RFM12B_CMD(0xC483); // AFC Command
    RFM12B_CMD(0x9827); // TX Configuration Command
    RFM12B_CMD(0xCC77); // PLL Command
    RFM12B_CMD(0xE000); // Wake-Up Timer Command
    RFM12B_CMD(0xC800); // Low Duty-Cycle Command
    RFM12B_CMD(0xC000); // LB Det./Clock Div. Command 2.2V, 1.66MHz
/// RFM12B_SEND                                       ///
/// Function: Send multiple bytes                     ///
void RFM12B_SEND(int *ptr, int16 size)
    int16 i;
    RFM12B_CMD(0x8238); // Enable Sender
    RFM12B_WRITE(0xAA); // Preamble
    RFM12B_WRITE(0xCE); // Sync HighByte
    RFM12B_WRITE(0xD4); // Sync LowByte
    for (i=0;i<size;i++)
        RFM12B_WRITE(*ptr); // DATA Byte
        ptr++;
    RFM12B_WRITE(0xAA); // Dummy Byte
    RFM12B_CMD(0x8208); // Disable Sender
/// RFM12B_RECEIVE                                    ///
/// Function: Receive multiple bytes                  ///
void RFM12B_RECEIVE(int *ptr, int16 size)
    int16 i;
    //RFM12B_CMD(0x82C8); // Init Receiver//test
    RFM12B_CMD(0x82D8); // Init Receiver//Candy
    //RFM12B_CMD(0xCA81); // Enable FIFO//test
    //RFM12B_CMD(0xCA83); // Clear FIFO//test
        *ptr = RFM12B_READ(); // Send Data
        ptr++;
     //RFM12B_CMD(0x8208); // Disable Receiver test of we hem wel aan laten staan
    //RFM12B_FIFO_RESET();
/// RFM12B_FIFO_RESET                                 ///
/// Function: Reset the FIFO                          ///
    RFM12B_CMD(0xCA81);
    RFM12B_CMD(0xCA83);
/// RFM12B_READ_STATUS                                ///
    int16 data;
    data = RFM12B_CMD(0x0000); // Read Data//test
    return (data);
   int buffi[16] ={1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16};
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   set_tris_a(0x00);
   delay_ms(250);
   RFM12B_INIT(1);
      RFM12B_SEND(buffi, 16);
      output_high(LED);
      output_low(LED);
RECEIVER CODE:
#include <16F886.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=mypcconn)
/// Functions:                                        ///
/// Updates:                                          ///
#define MISO      PIN_C5
#define nSEL      PIN_C2
#define SCK       PIN_C3
#define IRQ       PIN_B0
#define LED       PIN_A0
/// Definitions                                       ///
#define TX        1
#define RX        0
    nSEL_hi();
    SCK_lo();
    MOSI_lo();
/// RFM12B_CMD                                        ///
    int i;
    int16 temp=0;
    SCK_lo();
    nSEL_lo();
    for(i=0;i<16;i++)
        if(cmd&0x8000)
            MOSI_hi();
            MOSI_lo();
        delay_us(5);
        SCK_hi();
        delay_us(5);
        temp<<=1;
        if(in_MISO())
            temp|=0x0001;
        SCK_lo();
        cmd<<=1;
    nSEL_hi();
    return(temp);
    nSEL_lo();//test
    while(!in_MISO())
        ;//test
/// RFM12B_READ                                       ///
    int16 data;
    //RFM12B_WAIT_READY();
/// RFM12B_INIT                                       ///
    RFM12B_PORT_INIT();
    delay_ms(200);
    if (type)
        // Init Sender
        // Init Receive
    // General Init
/// RFM12B_SEND                                       ///
    int16 i;
        ptr++;
    int16 i;
        ptr++;
    RFM12B_CMD(0xCA81);
    RFM12B_CMD(0xCA83);
    int16 data;
    return (data);
   int buffi[16];
   int g = 0;
   setup_adc(ADC_OFF);
   set_tris_a(0x00);
   set_tris_c(get_tris_c()&(0b10111111));
   delay_ms(250);
   RFM12B_INIT(0);
      RFM12B_RECEIVE(buffi, 16);  //data receive
      for(g = 0; g < 16; g++) //send to pc (USART) received data
         putc(buffi[g]);
But the PC Received Data Incomprehensible.
Here is my circuit.
http://image.ohozaa.com/view/4kdtc
I'm trying for a week but can't succeed yet.
Help me please.
Thank you
PostPosted: Tue Nov 01, 2011 2:13 pm     Reply with quote
Delete the lines shown in bold below. Your programs are using software
SPI, and the lines in bold enable Hardware SPI. You don't want
that. Delete those two lines.
// Transmitter
setup_adc(ADC_OFF);
// Receiver
int buffi[16];
int g = 0;
setup_adc(ADC_OFF);
pingza1990
PostPosted: Wed Nov 02, 2011 1:07 am     Reply with quote
Thank you PCM programmer
but i still can't send data.
my project is the first PIC receive temperature form ds18b20
then forwarded to the second PIC with rfm12b and second send
the data to computer for processing.
Here is the code of the transmission temperature with rfm12b.
Transmitter
void ReadTemp_DS18B20(void)
    byte i, buffer[9];
    int temp,sign;
    if (touch_present()) {         // get present (reset)
        touch_write_byte(0xCC);    // Skip ROM
        touch_write_byte (0x44);   // Start Conversion
        delay_ms(200);             // delay 200 ms
        touch_present();           // get present (reset)
        touch_write_byte (0xBE);   // Read Scratch Pad
        for(i=0; i<9;i++)          // read 9 bytes
        buffer[i] = touch_read_byte();
    temp = (buffer[1]<<4)|(buffer[0]>>4);       // Temperature
    if(buffer[1]&0xF0) temp = (-1)*temp;        // Sign bit
      RFM12B_SEND(temp, 1);
  //  printf ("\nTemperature %d C",temp);*/
   setup_adc(ADC_OFF);
   set_tris_a(0x00);
   delay_ms(250);
   RFM12B_INIT(1);
      ReadTemp_DS18B20();
      output_high(LED);
      output_low(LED);
Receiver
   int temp;
   int g = 0;
   setup_adc(ADC_OFF);
   set_tris_a(0x00);
   delay_ms(250);
   RFM12B_INIT(0);
    RFM12B_RECEIVE(temp, 1);
     printf("TEMP %d ",temp);
temp at the transmitter is correct value.
but temp at the receiver always -1
Help me please
It will be sent next week.
Thank you
Very Happy
PostPosted: Wed Nov 02, 2011 11:35 am     Reply with quote
I don't have the RFM12b modules, so I can't really help very much.
