skillfox
RF module don't work, where is the problem? |
Posted: Fri Oct 21, 2011 9:44 am |
Transmitter:
#include <16f877A.h> // Kullanılacak denetleyicinin başlık dosyası tanıtılıyor.
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=4000000)
#use rs232 (baud=600, xmit=pin_C6, rcv=pin_C7)
#byte lcdport = 0x06
#byte lcdport_tris = 0x86
#include "3310.h"
char islem=0;
unsigned int a=0;
#int_rda
void serial_isr() {
islem=getch();
//putc(islem);
//disable_interrupts(int_rda);
void init()
lcdport_tris = 0x00; // lcdport all bits are outputs
port_b_pullups(TRUE);
nokia_init();
void main ()
init();
enable_interrupts(int_rda);
#if defined(__PCD__)
enable_interrupts(intr_global);
#else
enable_interrupts(global);
#endif
// delay_ms(10000);
//islem="null";
//islem=bgetc();
if (islem=='R'||islem=='r')
{ nokia_clean_ddram();
nokia_gotoxy(8,2);
printf(nokia_printchar," R geldi. ");
for(a=0;a<5;a++)
putc(0b01010101);
putc('x');
putc('R');
islem=0;
if (kbhit()) break;
if (islem=='L'||islem=='l')
nokia_gotoxy(8,2);
printf(nokia_printchar," L geldi. ");
for( a=0;a<5;a++)
putc(0b01010101);
putc('x');
putc('L');
islem=0;
if (kbhit()) break;
if (islem=='N'||islem=='n')
nokia_gotoxy(8,2);
printf(nokia_printchar," N geldi. ");
for( a=0;a<5;a++)
putc(0b01010101);
putc('x');
putc('N');
islem=0;
if (kbhit()) break;
if (islem=='U'||islem=='u')
nokia_gotoxy(8,2);
printf(nokia_printchar," U geldi. ");
for( a=0;a<5;a++)
putc(0b01010101);
putc('x');
putc('U');
islem=0;
if (kbhit()) break;
if (islem=='S'||islem=='s')
nokia_gotoxy(8,2);
printf(nokia_printchar," S geldi. ");
for( a=0;a<5;a++)
putc(0b01010101);
putc('x');
putc('S');
islem=0;
if (kbhit()) break;
Receiver 628a:
#include <16f628A.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOCPD
#use rs232 (baud=600, xmit=pin_b2, rcv=pin_b1)
int i=0,hiz=80;
char m=0,n=0;
const int yarim_adim[]={0x01,0x03,0x02,0x06,0x04,0x0C,0x08,0x09};
#int_rda
void seri_int()
if(getc()=='x')
m='x';
n=getc();
char a=0,temp=0;
#else
#endif
if(m=='x')
i = 0;
a=n;
if(a=='U')
hiz-=10;
a = temp;
if(a=='N')
hiz+=10;
a = temp;
if(a=='R')
temp = 'R';
for (;i<8;i++)
output_A(yarim_adim[i]);
delay_ms(hiz);
if (i==7)
i=0;
if (kbhit()) break;
if(a=='L')
temp = 'L';
for (;i>=0;i--)
if (i==0)
i=7;
output_a(yarim_adim[i]);
delay_ms(hiz);
if (kbhit()) break;
if(a=='S')
output_a(0x00);
and photo about my circuit.
![](http://i55.tinypic.com/c7rjd.jpg) |
Joined: 01 Jul 2010 Posts: 9162 Location: Greensville,Ontario
Posted: Fri Oct 21, 2011 11:10 am |
You don't post what RF module or a link to it's datasheet.
First thing I'd do is remove the RF modules and connect the PICs together serial-serial and verify taht the code actually works. If it works, then the RF modules are at fault, or the wiring to them, or some other problem... |
skillfox
hi |
Posted: Fri Oct 21, 2011 11:33 am |
temtronic wrote: | You don't post what RF module or a link to it's datasheet.
First thing I'd do is remove the RF modules and connect the PICs together serial-serial and verify that the code actually works. If it works, then the RF modules are at fault, or the wiring to them, or some other problem... |
Now i tried rf module and its working. I add a button to 877 and led to 628 and when i push the button led is lighting. And I look the data sheets everything is right
I have some problems about Codes. I'm waiting for ideas. |
