PMP on dsPIC33EP
nazoa
PMP on dsPIC33EP
PostPosted: Fri Oct 21, 2011 9:49 am     Reply with quote
Hello, I am planning to use the PMP in master mode with 16 address lines to control external SRAM on my project. Now, I also plan to share the data bus (E port) of the PMP with another peripheral. My question is, will this be possible? That is, will I be able to use the E port for input and output when not using the PMP without disturbing the PMP control lines (i.e. write and read strobe lines)?
