PIC18F14K50 slow output speed
berel
PostPosted: Thu Oct 20, 2011 2:56 am     Reply with quote
I am using the 18F14K50 with a 12 MHz crystal. When using a minimal program like
#include <18F14K50.h>
#fuses HS,NOWDT,NOLVP,NODEBUG,CPUDIV2,PLLEN
#use delay(clock=12M, crystal)
void main() {
   setup_ADC( ADC_OFF);
   output_low(PIN_C4);
   output_high(PIN_C4);
   output_low(PIN_C4);
   output_low(PIN_C4);
I see two pulses with a 8 µs width.
But in a code for a USB HID I obtain 340 ns pulses with the same fuses.
I have not found the reason for the "slow" pulses (delay_us also gives too long times).
Can anybody explain it ?
Thanks !
n-squared
PostPosted: Thu Oct 20, 2011 3:20 am     Reply with quote
Hi
You enble the PLL (#fuses PLLEN) but specify clock=12M.
Try:
#use delay(clock=48M,crystal=12M)
BR
NN
Every solution has a problem.
berel
PostPosted: Thu Oct 20, 2011 3:44 am     Reply with quote
Hi n-squared,
thanks for the hint: I tried so, but it did not make a change.
berel
PostPosted: Thu Oct 20, 2011 12:58 pm     Reply with quote
Post your CCS compiler version.
It's a 4-digit number (only) given at the start of the .LST file, which will be
in your project directory after you compile a file with no errors.
Example of version numbers:
http://www.ccsinfo.com/devices.php?page=versioninfo
Also, are you aware that your code as posted, does not have a loop,
and it will run one time only. Then it will execute the hidden SLEEP
instruction that CCS puts at the end of main() and it will shut down.
How are you measuring these pulses ? Must be a logic analyzer.
A scope wouldn't see it.
Or, this is a Proteus project. Is it ?
berel
PostPosted: Fri Oct 21, 2011 12:22 am     Reply with quote
PCH compiler version is 4.116, used within MPLAB 8.76
The code as posted is just a minimum code for testing. The target code is one for a HID USB device.
I am measuring the pulses with a Saleae logic analyzer as well as a TDS220 scope.
It is not a Proteus project (whatever it is ...).
In the complete code for the USB HID device, I found that a usb_init_cs() in front of the code for the pulses shows the 8 µs pulses again, wheras a usb_init() gives the short 170 ns pulses (CPUDIV1, PLLEN)
