Converting 10 bit ADC value to 14 bit midi message
Skirmitt
PostPosted: Fri Oct 14, 2011 1:22 am     Reply with quote
As stated in a previous topic I'm working on a midi controller. For the pitch fader I want to use 10 bit ADC values as it is far more accurate to beatmatch. This is the code I have so far. I don't think it works correctly. The LSB part is ok but the MSB part only goes from 0-7. I do want the MSB part also to go from 0-127. I'm not familiar with bitmasks and don't understand them completely.
set_adc_channel(0);
//get ADC
faderADC = read_adc();
//get LSB & MSB for a 14 bit number
faderLSB = (faderAdc & 0b0000000001111111);
faderMSB = (faderAdc & 0b0011111110000000)>>7; //is this correct ??
//check if value has changed
if ((faderADC < oldfaderADC - FADER_RANGE)||(faderADC > oldfaderADC + FADER_RANGE)) {
//send on pitchbend channel 1
midipitchbend(224, faderLSB, faderMSB);
oldfaderADC = faderADC;
These are the PIC settings
#include <16F886.h>
#device ADC=10
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
#use rs232(baud=31250, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#define FADER_RANGE 20
PostPosted: Fri Oct 14, 2011 2:05 am     Reply with quote
You need to become clear about intended data alignment. 10 bit to 14 bit can be either left or right aligned. Now you have it right alligned. You most likely want it left aligned to cover the full 14-Bit range. This implies the upper 7 bit of ADC value copied to high byte and the lower 3 to low byte, zero filling 4 bits.
Skirmitt
PostPosted: Fri Oct 14, 2011 3:23 am     Reply with quote
Adding this line did what I wanted:
faderADC = (faderADC << 4);
