How to drive PIC at 2KHz frequency?
Spradecom
PostPosted: Tue Oct 18, 2011 5:41 am     Reply with quote
I am using PIC 16F684 for light dimming application. Previously I had used 250Hz frequency. My application is to read ADC and generate PWM according to input of ADC, dimming from 420 count (2.0V ADC) to 921 count (4.5V ADC) from .2% to 100% (I from 2 to 1023 count) PWM, now I want to change PWM frequency from 250 Hz to 2 KHz. I have tried but change of ADC count occur also using timer0 interrupt overflow at 512us. What step i have followed to get proper output? Can any help me.
My initialization are following. Crystal Frequency 4MHz.
#int_TIMER0
void  TIMER0_isr(void)
   if(duty != new_duty)
         if(ramp_delay_counter < 5)
            ramp_delay_counter ++;
            if(duty < new_duty)
               duty ++;
            else if(duty > new_duty)
               duty --;
            ramp_delay_counter = 0;
         set_pwm1_duty(duty);
   setup_adc_ports(sAN2|sAN5|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_4,124,1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(0);
   setup_oscillator(OSC_4MHZ);
   setup_vref(FALSE);
   initialise_ports();
   init_variable();
   read_init_position();
       new_duty=collect_adc_data(5);
PostPosted: Tue Oct 18, 2011 2:08 pm     Reply with quote
This program will create a PWM signal on pin C2 with a frequency of
2.0 KHz. Try it. It works.
#include <16F877.H>
setup_timer_2(T2_DIV_BY_4, 124, 1);
set_pwm1_duty(62);
Spradecom
PostPosted: Tue Oct 18, 2011 10:46 pm     Reply with quote
Thanks sir for your valuable response. If I want to use 10bit ADC and 10 Bit PWM with 2KHzs freqency how to use program?
I had worked with 250Hzs it gives proper output but frequency changes from 250 Hzs to 2 KHzs.output does not give proper.
PostPosted: Tue Oct 18, 2011 10:55 pm     Reply with quote
Example programs in which the PWM duty cycle is set by ADC value:
http://www.ccsinfo.com/forum/viewtopic.php?t=40222&start=1
http://www.ccsinfo.com/forum/viewtopic.php?t=43169&start=1
