what to do, I can't understand
freedom
PostPosted: Fri Oct 07, 2011 4:32 am     Reply with quote
Hello all
I'm new in pic programming.
I want to do:
When push switch 1 pressed, corresponding output enable and the timer run for mentioned time and then output off. Here I used a variable 'p' to assign the timing parameter.
When push switch 2 pressed, corresponding output enable and the timer run for another mentioned time and then output off. Here I used a variable 'q' to assign the timing parameter.
I don't want to use delay because in delay time other instruction of program isn't executed.
Please help and give me suggestion.
Here is my code.
#include <16F877A.H>
#use delay(clock = 4000000)
#include <flex_LCD420.c>
#int_timer0
int16 p,q;
 timer0_isr()
p++;
q++;
   setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_4);
   enable_interrupts (INT_TIMER0);
   enable_interrupts(global);
   set_timer0(6);
// Clear the LCD.
printf(lcd_putc, "\f");
delay_ms(50);
   printf(lcd_putc, "\f  PIC Experiment");
   printf(lcd_putc, "\n--------------------");
   printf(lcd_putc, "\nNice Day ");
   if (!input(pin_D0))    // switch 1
   {output_high(pin_C0);}
   if (p==1000)
   {output_low(pin_C0);
   p=0;}
   if (!input(pin_D1))        // switch 2
   {output_high(pin_C1);}
  if (q==500)
   {output_low(pin_C1);
  q=0;}
PostPosted: Fri Oct 07, 2011 5:01 am     Reply with quote
First off you don't say what value or range the delays are. Anything from nanoseconds to days is possible with this PIC! So more information is required.
Also since this high level language allows for long variable names, I suggest something more descriptive in place of 'p' and 'q'. It'll help you and others, days or weeks from now, when you're working on this project.
You need some kind of 'debouncing' routine on those 'switches'! Unless you're using expensive electronic switches as mechanical ones are 'noisey'!
Concurrent countdown timers are easy to implement, several ways to do it. Microchip has several examples in their 'Designing for Dollars' applications handbook. As well, CCS kindly supplies example code in the 'examples' folder, that would be useful to you.
And of course the Internet is FULL of code that will do the project you describe.
PostPosted: Fri Oct 07, 2011 12:54 pm     Reply with quote
You have another thread back in August, where you are working on the
same problem:
http://www.ccsinfo.com/forum/viewtopic.php?t=35429
In that thread, you were given a link that shows how to do simple multi-tasking:
Here is another one:
http://www.ccsinfo.com/forum/viewtopic.php?t=17189
The problem is that your skill level is still at a "beginner". You must be
at least at an intermediate level to understand this type of program.
You need to keep learning C for a few months, so you can understand it,
or find someone else to do your coding. I don't want to do your project
for you.
freedom
PostPosted: Fri Oct 07, 2011 2:31 pm     Reply with quote
same problem:
Dear PCM programmer , above mentioned link the suspected isn't me.
But its true that I'm a beginner.
in this forum, I never expect that someone write my code. I just expect some examples or guidelines.
I'm living in a small town in the country named Bangladesh, nobody here that can help me.
Only some downloaded books and internet and this forum only the way.
I start to learn c by this book "Programming 8-bit PIC Microcontrollers in C
by Martin P.Bates "
If you have a good suggestion on book/tutorial for the beginner like me please help.
PostPosted: Fri Oct 07, 2011 2:48 pm     Reply with quote
OK, then the first thing you need to do is to fix this:
#int_timer0
int16 p,q;
timer0_isr()
p++;
q++;
You can't put anything between the #int_xxxx statment and the isr
function. If you do that, the isr code will not be compiled (and the
compiler will not tell you this). You can see this in the .LST file, shown
below. Notice there is no ASM code generated:
.................... #int_timer0
.................... int16 p,q;
....................  timer0_isr()
.................... p++;
.................... q++;
.................... void main()
This is the correct way:
int16 p,q;
#int_timer0
timer0_isr()
p++;
q++;
Compile it as above, and notice that you now get ASM code generated:
0037:  INCF   28,F
0038:  BTFSC  003.2
0039:  INCF   p+1,F
003A:  INCF   2A,F
003B:  BTFSC  003.2
003C:  INCF   q+1,F
003D:  BCF    00B.2
003E:  BCF    00A.3
003F:  BCF    00A.4
0040:  GOTO   01B
So you need to fix that part of your program, and then you can continue
with the program development.
freedom
PostPosted: Sat Oct 08, 2011 7:53 am     Reply with quote
Dear PCM programmer
Thanks a lot for your kind help and guideline.
by Martin P.Bates".
Do you have have any good suggestion on book/tutorial for the beginner like me please help.
If so, please provide me some link.
Thank you once again.
PostPosted: Sat Oct 08, 2011 11:59 am     Reply with quote
Here are some threads on books:
http://www.ccsinfo.com/forum/viewtopic.php?t=27839
http://www.ccsinfo.com/forum/viewtopic.php?t=33272
This post has many links to online tutorials on C and CCS and PICs:
http://www.ccsinfo.com/forum/viewtopic.php?t=46384&start=3
freedom
PostPosted: Sun Oct 09, 2011 5:50 am     Reply with quote
thanks a lot
freedom
PostPosted: Sun Oct 09, 2011 8:35 am     Reply with quote
Now the code is working but I suspect a problem while I simulate it with Proteus 7.7.
I suspect timing is not accurate as I want to do start the timer at the point that is noted in the code.
what to do:
int16 p,q;
#int_timer0
 timer0_isr()
p++;
q++;
   set_timer0(6);
// Clear the LCD.
delay_ms(50);
   {output_high(pin_C0);} // I want to start the timer at this point
   if (p==1000)
   p=0;}
   {output_high(pin_C1);}   // I want to start the timer at this point
  if (q==500)
  q=0;}
PostPosted: Sun Oct 09, 2011 9:49 am     Reply with quote
You have two and only Two options.
1) Hack into Proteus and FIX one of the many bugs and errors that it has....
2) Get RID of PROTEUS and use real hardware !
I suspect that option #2 is your only choice.
freedom
PostPosted: Sun Oct 09, 2011 1:55 pm     Reply with quote
Thanks temtronic
Actually I suspect there is a bug in my code not in Proteus.
Anyway, in my code is it really timing accurately as per my desire .
Maybe I mistake something.
PostPosted: Sun Oct 09, 2011 5:20 pm     Reply with quote
My advice is to make a more simple program. Just use one button and
one LED. Get that working reliably. Then add more features later.
FvM
PostPosted: Mon Oct 10, 2011 12:29 am     Reply with quote
But you don't. Starting the timer would involve resetting the timer variable.
freedom
PostPosted: Mon Oct 10, 2011 3:42 am     Reply with quote
Many thanks FvM for your valued suggestion.
You are right.
Now its working.
