INT01
setup_timer_2 function |
Posted: Thu Oct 06, 2011 4:19 am |
When I use the setup_timer_2() function I get this:
491: setup_timer_2(T2_DIV_BY_16,255,5);
10D2 0E20 MOVLW 0x20
10D4 0906 IORLW 0x6
10D6 6ECA MOVWF SSP1MSK, ACCESS
10D8 0EF9 MOVLW 0xff
10DA 6ECB MOVWF SSP1CON3, ACCESS
Why?
PIC18F46K22 with V4.114 |
Joined: 01 Jul 2010 Posts: 9161 Location: Greensville,Ontario
Posted: Thu Oct 06, 2011 9:44 am |
I suggest reading the section on Special Function Registers as well as the SSP chapters for whatever PIC you're using.
Then 'play computer' and see what bits are being set/cleared on those registers.
Learn by doing....the more you read, the more you'll understand. |
Posted: Thu Oct 06, 2011 2:36 pm |
10D4 0906 IORLW 0x6
Why?
That function writes to the wrong registers in your compiler version.
Here's a macro that will replace the defective function. Just put it
above main() as shown below. Then call setup_timer_2() and it will
put in the correct code. Example:
#include <18F46K22.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
// This macro replaces the CCS built-in function setup_timer_2():
#byte T2CON = 0xFBA
#byte PR2 = 0xFBB
#define setup_timer_2(t2_mode, t2_period, t2_ps) \
T2CON = (t2_mode | ((t2_ps -1) << 3)); \
PR2 = (t2_period);
setup_timer_2(T2_DIV_BY_16, 255, 5);
This problem doesn't occur in vs. 4.124. CCS must have fixed it sometime
after vs. 4.114. (Note: This is a problem with 18F46K22 for that version,
not all PICs). |
