Enter the correct code to turn led on... problem
aymanoo
PostPosted: Mon Sep 26, 2011 1:30 pm     Reply with quote
The objective of my project is to turn led c0 when I enter the correct code so first I'm trying code of one character ("5") on keypad but its not working. Another question what if I have to enter for example the code "123" on keypad to turn the led on ? What do I have change in my code?
#include<16f887.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=2000000)
#define use_portb_kbd TRUE
#include<lcd.c>
#include<kbd.c>
char k;
lcd_init();
kbd_init();
lcd_putc("\f ready....\n");
while (true)
 k=kbd_getc();
 if(k!=0)
    if(k=='*')
       lcd_putc('\f');
       lcd_putc(k);
if(k=='5')
  output_high(pin_c0);
  output_low(pin_c0);
AYMAN
PostPosted: Mon Sep 26, 2011 3:01 pm     Reply with quote
You have this set for 2 MHz. You probably want 20 MHz.
Hint: it's easier and more reliable to do it this way:
#use delay(clock=20M)
What if I have to enter for example the code "123" on keypad to turn the led on ?
Keypad password demo program:
http://www.ccsinfo.com/forum/viewtopic.php?t=45935
PostPosted: Mon Sep 26, 2011 3:52 pm     Reply with quote
Just a hint for why your program might not work as expected: your led is blinking so fast that you won't see it. Try adding a delay. Not the perfect solution, but it will do for a simple test:
if(k=='5')
  delay_ms(300);
  output_low(pin_c0);
PostPosted: Mon Sep 26, 2011 4:03 pm     Reply with quote
Another option would be to change it so '5' turns the LED on and '4' turns
it off:
if(k=='5')
if(k=='4')
  output_low(pin_c0);
