picnic
PIC18F46K22 Compiler Problem? |
Posted: Wed Dec 21, 2011 10:06 am |
I've been trying to use the Weak Pull-up feature of Port B, I got erroneous results. Examining the ASM output showed the compiler using the wrong register value for the port_b_pullups() call.
Also GETENV("SFR:TXSTA1") gives 0. Have I got the name wrong or is this (and maybe its ilk) missing?
Compiler version 4.127 |
Posted: Wed Dec 21, 2011 2:27 pm |
Put the following 4 lines above main(). This macro (with the #define
statement) will replace the buggy built-in port_b_pullups() function:
#byte WPUB = 0xF61
#byte INTCON2 = 0xFF1
#bit RBPU = INTCON2.7
#define port_b_pullups(x) WPUB = x; x ? (RBPU = 0) : (RBPU = 1); |
Quote: | Also GETENV("SFR:TXSTA1") gives 0.
I didn't get that. If I compile the program shown below with vs. 4.127
and look at the .LST file, I see this:
Quote: | ....................
.................... result = TXSTA1;
00032: MOVFF FAC,05
0xFAC is the correct register address of TXSTA1 in the 18F46K22.
This was tested with vs. 4.127.
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#byte TXSTA1 = getenv("SFR:TXSTA1")
int8 result;
result = TXSTA1;
Posted: Wed Dec 21, 2011 4:08 pm |
Though the posted version of GETENV should work, there have been problems reported with the latest compilers, being 'strict' about the presence of spaces or tabs. So if you use a tab between the '=' and the GETENV, problems have been seen, and if extra spaces are added some problems also seem to occur. Type it exactly as PCM_programmer has it, and it does work.
picnic
Posted: Thu Dec 22, 2011 2:53 am |
Thanks for the help guys |
