PIC18F4550 fuse - hello world
PostPosted: Fri Sep 23, 2011 5:32 am     Reply with quote
Maybe you can teach an old dog new tricks? I'm thinking of migrating to the PIC18F4550 as it's cheaper, faster, more powerful than the PIC16F877 I've used for the past 2 decades. But, like others I'm confused about the FUSES options. I want to stay using an external 20MHz xtal. Could someone post a FUSES list that works? I haven't got the right combination as the RS232 to PC is 'off'.
No USB is need, that's for the future...maybe.
Thanks.
asmboy
PostPosted: Fri Sep 23, 2011 8:14 am     Reply with quote
My first use of the 18f family was with an 18f4520 and i had trouble making the USART work too.
I use fast_io () on ALL Ports all the time in all programs.
(just my a n a l retentive side i guess)
Adding this to my init routine fixed my problem back then
with compiler ver 4.085
#bit spen = 0xFAB.7
     set_tris_c (  0b11000011 ); // 00000011   C0,C1 are  inputs
     spen=1; // for usart
BTW you did not post your fuses that you used - so i cant see if i think any of them are a problem either.
PostPosted: Fri Sep 23, 2011 10:47 am     Reply with quote
[solved]...whew....
turns out I need HS NOT HSPLL to make my PIC run 'right'...
Too many fuses for old guys like me to figure out !!!
Progress though...one small step....
