mcn
about How to use GPS Decode codes from library |
Posted: Wed Sep 21, 2011 5:07 am |
I trying read of GPS module by serial port.
I want to use to "GPRMC GPS message decode" from Code library.
GPRMC GPS message decode is here from code library.
http://www.ccsinfo.com/forum/viewtopic.php?t=45827
How can I write Latitude, Longitude and speed to 2x16 lcd by using this code?
Thanks, good luck. |
mcn
Posted: Wed Sep 21, 2011 9:06 am |
anybody? |
dilandau
Posted: Wed Sep 21, 2011 9:18 am |
Sorry but I cannot understand properly your problem...
Your question is about capturing NMEA GPRMC Data from a GPS, or showing it in a LCD 2x16?
By your code it seems that you already know how to "handle" a whole NMEA phrase. But you are not showing how you get it. Is that your problem?
By the way, I would check for NMEA CRC in that void GPRMC_decode function of yours.
If your problem is writing to a LCD I would change the topic name. If this is your case, which LCD are you using?, it is pararell or I2C?... |
mcn
Posted: Wed Sep 21, 2011 9:45 am |
dilandau,
My big problem is about capturing NMEA GPRMC Data from a GPS.
I use 2x16 parallel lcd. LCD writing is not a big problem. |
asmboy
Posted: Wed Sep 21, 2011 3:10 pm |
do you mean you do not know how to read serial data ?
do you have a circuit schematic that shows the hardware
you propose to use ?
have a pic part you are using ?
you need to be a lot more clear.
tell more about whta you are doing - and what you have done on your own first - and you will get better replies. |
