arunb
[SOLVED] Receive problems with MRF24J40MA module |
Posted: Tue Sep 27, 2011 2:59 am |
I am working on the MRf24J40MA module, I have managed to send and receive a few packets using two identical MRf24J40MA modules connected to 2 18F2620 mcus.
To receive packets I use the INT pin of the module connected to B0 of the mcu, though I can detect packets (INT line goes low), I get wrong data while reading the RXFIFO buffer. But sometimes packets are read correctly.
Can anyone advise why this occurs ???
Also as the mcu runs on +5 V , I use a 10K and 15K resistor divider to get 3 V for the output ports to the MRF module, the SDO and the INT pins are connected to B0 and B1 pins of the 18f2620 mcu.
The datasheet mentions these pins as TTL buffers, and can detect a high of at least 2.5 Volts.
Is my inference correct ??, or do I have to use a transistor stage to get a +5V high ??
thanks
a
asmboy
Posted: Tue Sep 27, 2011 7:31 am |
You could have several problems -but what comes to mind is
not having proper 5v 3.3v translation.
How are you level matching your SPI lines ?? |
Posted: Tue Sep 27, 2011 1:28 pm |
Quote: | the SDO and the INT pins are connected to B0 and B1 pins of the 18f2620 mcu.
Are you polling the MRF24J40MA INT signal on pin B1, or are you using
the INT1 interrupt capability of Pin B1 ? Do you have #INT_EXT1 interrupts
enabled in your program ? |
arunb
RE: |
Posted: Wed Sep 28, 2011 12:13 am |
Sorry for the delay in replying..
I have actually managed to solve the problem, it seems the erratic receive operation was because the interrupts were not being cleared just after initialising the MRF module. Once I did this, the system started to work flawlessly.
I have a 10K and 15K resistor divider for the PIC output lines, whereas the INT line of the MRf24J40MA module is directly connected to port b0 of the 18F2620 and the SDO is pulled up to 3.3V using a 2.7K resistance and is connected to port b1.
The 3 V supply for the MRf24J40MA module is derived using a LM117 regulator.
I am polling pin b0 for a low state instead of using the external interrupt on b0.
Thanks for the help.
a |
asmboy
Posted: Wed Sep 28, 2011 6:22 am |
glad you got it !!
but i'd like to add to those who read this thread -
re: 10K and 15K resistor"
you can get better level translation ( more frequency span)
if you try more divider current / lowwer'Z' by using
2k and 3K as your resistors -
if the frequencies involved are high enough - stray capacitance in parallel with the 15k resistor can provide extra un- intended attenuation.
IMB all passive 3.3/5V translation- especially at significant ( over 500 khz) clock speed -is a bit dodgey |
arunb
RE; |
Posted: Thu Sep 29, 2011 8:49 am |
Thanks again, I will change that to 2K and 3K resistors.
I was using the 74VHC08 for level translation, but the IC became unavailable for a long time, so I had to change to resistances.
thanks
a |
