HW SPI
jmaudley
HW SPI
PostPosted: Wed Sep 14, 2011 10:05 am     Reply with quote
Hi, - I'm new to the CCS compiler and programming in C, but not new to programming PICs.
I'm trying to drive an HCMS-2963 display using the SPI interface.
I'm using a 16f876a chip and pins are configured correctly for hardware SPI implementation.
I've read the manual and #use spi seems to be quite simple (unless I'm missing the point).
My understanding is that once I have set the following line:
#use spi (FORCE_HW, BITS=8, STREAM=SPI_STREAM)
All i need to do is:
spi_xfer(data);
To send out my data.
Am I correct in saying that #use spi handles all of the configuration or do I need set the appropriate registers.
If anybody could point me in the direction of some code examples that would be really helpful.
Any assistance would be appreciated. Thx
PostPosted: Wed Sep 14, 2011 12:16 pm     Reply with quote
Whether or not #use spi() works, or also, what specific parameters are
required, is highly dependent upon your compiler version. Please post
your version.
jmaudley
PostPosted: Thu Sep 15, 2011 1:20 am     Reply with quote
I'm using the PCWH compiler
IDE 4.107
PCB 4.107
PCM 4.107
PCH 4.107
PostPosted: Thu Sep 15, 2011 3:07 pm     Reply with quote
I think it would be much easier to use the setup_spi() method of
configuring the hardware SPI module. Example:
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16);
Then, to write an 8-bit value to the slave, you can use:
spi_write(data);
Here are some examples of spi driver code:
http://www.ccsinfo.com/forum/viewtopic.php?t=44786&start=1
http://www.ccsinfo.com/forum/viewtopic.php?t=37687&start=11
http://www.ccsinfo.com/forum/viewtopic.php?t=45258&start=3
http://www.ccsinfo.com/forum/viewtopic.php?t=41008&start=5
http://www.ccsinfo.com/forum/viewtopic.php?t=40443&start=1
jmaudley
PostPosted: Fri Sep 16, 2011 1:38 am     Reply with quote
Thanks for the advice.
I'll give that a try.
jmaudley
PostPosted: Fri Sep 16, 2011 7:57 am     Reply with quote
Very Happy
Got it working (my first C project).
Good to know I'm not on my own.
PCM programmer - thx for taking the time to help.
