eca
pic24F16KA102 and I2C problem |
Posted: Tue Sep 06, 2011 3:55 am |
I'm trying to make a 24F16KA102 work in slave I2C mode. As I wasn't able to make it run, then I tried to make a tiny test program to make this micro work as a I2C master. I used the 24 bits wizard of PCWHD 4.109 and I get the following code:
#include <24F16KA102.h>
#FUSES NOBSS //No boot segment
#FUSES PR //Primary Oscillator
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES OSCIO //OSC2 is general purpose output
#FUSES POSCFREQ_H
#FUSES SOSC_HIGH
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES PUT //Power Up Timer
#FUSES BORV_LOW
#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES DSWDT2147483648
#FUSES DSWDTCK_LPRC
#FUSES NODSBOR
#FUSES NODSWDT
//#FUSES NOALTI2C //I2C mapped to SDA1/SCL1 pins
#use i2c(Master,slow,sda=PIN_B9,scl=PIN_B8,force_hw,NOFLOAT_HIGH)
setup_wdt(WDT_Off);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
// TODO: USER CODE!!
// prueba de funcionamiento...
output_high(PIN_A6);// this is only an start-up check signal
output_low(PIN_A6);
output_low(PIN_A6);
while(1) {
i2c_start();
i2c_write(0xa2);
i2c_write(123);
i2c_stop();
delay_ms(20);
NOTES:
I used both #FUSES NOALTI2C and #FUSES ALTI2C.
I also used forced_hw and forced_sw.
I tried #use i2c for 'slow' and 'fast'.
NOFLOAT_HIGH
I always got no signals at all at PIN_B9 and PIN_B8. They are always at low level.
What is the problem?
Someone has a checked and tested right master i2c program using B9 & B8 pins that I could test in my circuit?
Any sample code to make this micro work as slave using interrupts to get a single data from i2c?
Thanks in advance! |
Posted: Tue Sep 06, 2011 4:02 am |
You have got the pull-up resistors on the I2C bus?.
I2C, is an 'active low' bus, with the devices _only_ pulling the lines down. The bus requires a pull-up resistor on each of the two lines to pull the signals high when they are not driven. Typically something like 1.2 to 4.7KR for 5v I2C (depending on the bus length/capacitance), and dropping by 50% for a 3.3v I2C bus.
eca
Posted: Tue Sep 06, 2011 6:40 am |
Couldn't be used NOFLOAT_HIGH to force a high level instead of pull-ups?
This is intended only to check that the i2c module is working and clk and sda signals are generated. |
Posted: Tue Sep 06, 2011 8:58 am |
NOFLOAT_HIGH can't work with hardware I2C, with software I2C, it apparently misses to set the pins to output for PIC24 (TRISB.x = 0). You shouldn't connect I2C peripherals when NOFLOAT_HIGH is selected, otherwise you're creating a bus contention for SDA. |
