treitmey
Nokia 3310 LPH7779 rev 3 V3 Michel Bavin |
Posted: Tue Jan 03, 2006 9:35 am |
Copy and past from main forum
I'm taking no responsibility for this code.
It has no copy right text, But it shows the author.
contact author for permission.
Graphic LCD Nokia 3310 (LPH7779) routines v3
CCS compiler
by Michel Bavin 2004 --- bavin@skynet.be --- http://users.skynet.be/bk317494/ ---
august 29, 2004
// ex:
// nokia_init();
// nokia_gotoxy(0,0);
// printf(nokia_printchar,"test???");
#define nok_sclk PIN_D4
#define nok_sda PIN_D3
#define nok_dc PIN_D2
#define nok_cs PIN_D1
#define nok_res PIN_D0
char char_row,charsel,charpos,chardata; // for nokia_3310 lcd
int16 ddram;
char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE5[240]= {0x00,0x00,0x00,0x00,0x00, // 20 space ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
0x00,0x00,0x5f,0x00,0x00, // 21 !
0x00,0x07,0x00,0x07,0x00, // 22 "
0x14,0x7f,0x14,0x7f,0x14, // 23 #
0x24,0x2a,0x7f,0x2a,0x12, // 24 $
0x23,0x13,0x08,0x64,0x62, // 25 %
0x36,0x49,0x55,0x22,0x50, // 26 &
0x00,0x05,0x03,0x00,0x00, // 27 '
0x00,0x1c,0x22,0x41,0x00, // 28 (
0x00,0x41,0x22,0x1c,0x00, // 29 )
0x14,0x08,0x3e,0x08,0x14, // 2a *
0x08,0x08,0x3e,0x08,0x08, // 2b +
0x00,0x50,0x30,0x00,0x00, // 2c ,
0x08,0x08,0x08,0x08,0x08, // 2d -
0x00,0x60,0x60,0x00,0x00, // 2e .
0x20,0x10,0x08,0x04,0x02, // 2f /
0x3e,0x51,0x49,0x45,0x3e, // 30 0
0x00,0x42,0x7f,0x40,0x00, // 31 1
0x42,0x61,0x51,0x49,0x46, // 32 2
0x21,0x41,0x45,0x4b,0x31, // 33 3
0x18,0x14,0x12,0x7f,0x10, // 34 4
0x27,0x45,0x45,0x45,0x39, // 35 5
0x3c,0x4a,0x49,0x49,0x30, // 36 6
0x01,0x71,0x09,0x05,0x03, // 37 7
0x36,0x49,0x49,0x49,0x36, // 38 8
0x06,0x49,0x49,0x29,0x1e, // 39 9
0x00,0x36,0x36,0x00,0x00, // 3a :
0x00,0x56,0x36,0x00,0x00, // 3b ;
0x08,0x14,0x22,0x41,0x00, // 3c <
0x14,0x14,0x14,0x14,0x14, // 3d =
0x00,0x41,0x22,0x14,0x08, // 3e >
0x02,0x01,0x51,0x09,0x06, // 3f ?
0x32,0x49,0x79,0x41,0x3e, // 40 @
0x7e,0x11,0x11,0x11,0x7e, // 41 A
0x7f,0x49,0x49,0x49,0x36, // 42 B
0x3e,0x41,0x41,0x41,0x22, // 43 C
0x7f,0x41,0x41,0x22,0x1c, // 44 D
0x7f,0x49,0x49,0x49,0x41, // 45 E
0x7f,0x09,0x09,0x09,0x01, // 46 F
0x3e,0x41,0x49,0x49,0x7a, // 47 G
0x7f,0x08,0x08,0x08,0x7f, // 48 H
0x00,0x41,0x7f,0x41,0x00, // 49 I
0x20,0x40,0x41,0x3f,0x01, // 4a J
0x7f,0x08,0x14,0x22,0x41, // 4b K
0x7f,0x40,0x40,0x40,0x40, // 4c L
0x7f,0x02,0x0c,0x02,0x7f, // 4d M
0x7f,0x04,0x08,0x10,0x7f, // 4e N
0x3e,0x41,0x41,0x41,0x3e // 4f O
BYTE const TABLE6[240]= {0x7f,0x09,0x09,0x09,0x06, // 50 P
0x3e,0x41,0x51,0x21,0x5e, // 51 Q
0x7f,0x09,0x19,0x29,0x46, // 52 R
0x46,0x49,0x49,0x49,0x31, // 53 S
0x01,0x01,0x7f,0x01,0x01, // 54 T
0x3f,0x40,0x40,0x40,0x3f, // 55 U
0x1f,0x20,0x40,0x20,0x1f, // 56 V
0x3f,0x40,0x38,0x40,0x3f, // 57 W
0x63,0x14,0x08,0x14,0x63, // 58 X
0x07,0x08,0x70,0x08,0x07, // 59 Y
0x61,0x51,0x49,0x45,0x43, // 5a Z
0x00,0x7f,0x41,0x41,0x00, // 5b [
0x02,0x04,0x08,0x10,0x20, // 5c
0x00,0x41,0x41,0x7f,0x00, // 5d
0x04,0x02,0x01,0x02,0x04, // 5e
0x40,0x40,0x40,0x40,0x40, // 5f
0x00,0x01,0x02,0x04,0x00, // 60
0x20,0x54,0x54,0x54,0x78, // 61 a
0x7f,0x48,0x44,0x44,0x38, // 62 b
0x38,0x44,0x44,0x44,0x20, // 63 c
0x38,0x44,0x44,0x48,0x7f, // 64 d
0x38,0x54,0x54,0x54,0x18, // 65 e
0x08,0x7e,0x09,0x01,0x02, // 66 f
0x0c,0x52,0x52,0x52,0x3e, // 67 g
0x7f,0x08,0x04,0x04,0x78, // 68 h
0x00,0x44,0x7d,0x40,0x00, // 69 i
0x20,0x40,0x44,0x3d,0x00, // 6a j
0x7f,0x10,0x28,0x44,0x00, // 6b k
0x00,0x41,0x7f,0x40,0x00, // 6c l
0x7c,0x04,0x18,0x04,0x78, // 6d m
0x7c,0x08,0x04,0x04,0x78, // 6e n
0x38,0x44,0x44,0x44,0x38, // 6f o
0x7c,0x14,0x14,0x14,0x08, // 70 p
0x08,0x14,0x14,0x18,0x7c, // 71 q
0x7c,0x08,0x04,0x04,0x08, // 72 r
0x48,0x54,0x54,0x54,0x20, // 73 s
0x04,0x3f,0x44,0x40,0x20, // 74 t
0x3c,0x40,0x40,0x20,0x7c, // 75 u
0x1c,0x20,0x40,0x20,0x1c, // 76 v
0x3c,0x40,0x30,0x40,0x3c, // 77 w
0x44,0x28,0x10,0x28,0x44, // 78 x
0x0c,0x50,0x50,0x50,0x3c, // 79 y
0x44,0x64,0x54,0x4c,0x44, // 7a z
0x00,0x08,0x36,0x41,0x00, // 7b
0x00,0x00,0x7f,0x00,0x00, // 7c
0x00,0x41,0x36,0x08,0x00, // 7d
0x10,0x08,0x08,0x10,0x08, // 7e
0x78,0x46,0x41,0x46,0x78 // 7f
void nokia_init(void);
void nokia_write_command(char bytefornokia_command);
void nokia_write_data(char bytefornokia_data);
void nokia_write_dorc(char bytefornokia);
void nokia_gotoxy(int8 xnokia, int8 ynokia);
void nokia_erase_y(int8 ynokia);
void nokia_erase_x(int8 xnokia);
void nokia_printchar(int8 cvar);
void nokia_clean_ddram(void);
void table_to_nokialcd(void);
void nokia_plot(int8 xnokia,int8 plot_value8);
void nokia_write_data_inv(char bytefornokia_data_inv);
void nokia_clear_screen(void);
void nokia_clear_xy(int8 xnokia, int8 ynokia);
void nokia_print_uparrow(void);
void nokia_print_downarrow(void);
void nokia_print_leftarrow(void);
void nokia_print_rightarrow(void);
void nokia_print_degree(void);
void nokia_print_lowbatdegree(void);
output_high(nok_dc); // bytes are stored in the display data ram, address counter, incremented automatically
output_high(nok_cs); // chip disabled
output_low(nok_res); // reset chip during 250ms
delay_ms(10); // works with less.....
output_high(nok_res);
nokia_write_command(0x21); // set extins extended instruction set
nokia_write_command(0xc2); // Vop v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v) ********************************************************************************************************************
nokia_write_command(0x13); // bias
nokia_write_command(0x20); // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
nokia_write_command(0x09); // all on
nokia_clean_ddram(); // reset DDRAM, otherwise the lcd is blurred with random pixels
nokia_write_command(0x08); // mod control blank change (all off)
nokia_write_command(0x0c); // mod control normal change
nokia_gotoxy(0,0); // 84*6=504 clear LCD
for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
output_low(nok_dc); // byte is a command it is read with the eight SCLK pulse
output_low(nok_cs); // chip enabled
nokia_write_dorc(bytefornokia_command);
nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia) // serial write data or command subroutine
char caa;
for (caa=8;caa>0;caa--) {
output_low(nok_sclk);
// delay_us(2);
if ((bytefornokia&0x80)==0){output_low(nok_sda);}
else {output_high(nok_sda);}
output_high(nok_sclk);
bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia) // Nokia LCD 3310 Position cursor
nokia_write_command(0x40|(ynokia&0x07)); // Y axe initialisation: 0100 0yyy
nokia_write_command(0x80|(xnokia&0x7f)); // X axe initialisation: 1xxx xxxx
nokia_gotoxy(0,ynokia);
printf(nokia_printchar," ");
char column;
for (column=0;column!=6;column++){
nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar) // Write 1 character to LCD
charsel=cvar;
table_to_nokialcd();
void table_to_nokialcd(void) // extract ascii from tables & write to LCD
if (charsel<0x20)return;
if (charsel>0x7f)return;
for (char_row=0;char_row<5;char_row++) { // 5 bytes
if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE5[(charpos+char_row)];} // use TABLE5
else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE6[(charpos+char_row)];} // use TABLE6
nokia_write_data(chardata); // send data to nokia
nokia_write_data(0x00); // 1 byte (always blank)
char i;
plot_value32=0;
// plot_value32|=1; // unremark this if you want dotgraph instead of bargraph
for (i=0;i!=plot_value8;i++){
plot_value32|=1; // remark this if you want dotgraph instead of bargraph
plot_value32<<=1;
plot_value32|=2; // bottom line is always filled
plot_llsb=(plot_value32&0xff);
plot_ulsb=((plot_value32>>8)&0xff);
plot_lmsb=((plot_value32>>16)&0xff);
plot_umsb=((plot_value32>>24)&0xff);
nokia_gotoxy(xnokia,1);
nokia_write_data_inv(plot_umsb);
nokia_gotoxy(xnokia,2);
nokia_write_data_inv(plot_lmsb);
nokia_gotoxy(xnokia,3);
nokia_write_data_inv(plot_ulsb);
nokia_gotoxy(xnokia,4);
nokia_write_data_inv(plot_llsb);
char caa;
delay_us(2);
if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
bytefornokia_data_inv=bytefornokia_data_inv>>1;
nokia_erase_y(0);
nokia_erase_y(1);
nokia_erase_y(2);
nokia_erase_y(3);
nokia_erase_y(4);
nokia_erase_y(5);
nokia_gotoxy(xnokia,ynokia);
nokia_printchar(" ");
nokia_write_data(0x04);
nokia_write_data(0x02);
nokia_write_data(0x7f);
nokia_write_data(0x10);
nokia_write_data(0x20);
nokia_write_data(0x08);
nokia_write_data(0x1c);
nokia_write_data(0x2a);
nokia_write_data(0xf8);
nokia_write_data(0x06);
nokia_write_data(0x09);
// nokia_printchar(" ");
nokia_write_data(0x0f);
barkerben
Posted: Sun Feb 05, 2006 1:37 pm |
Can anyone confirm this code works? I'm debugging a circuit, and can't get anything upon the LCD (a 3310). The software looks fine though...
Ben |
gs
Joined: 22 Aug 2005 Posts: 30 Location: Ioannina - Greece
Posted: Sun Feb 05, 2006 4:35 pm |
This code works, I used it in two of my projects.
I originally found it here
Works nice  _________________ www.hlektronika.gr |
barkerben
Posted: Sun Feb 05, 2006 6:41 pm |
Ok...I guess I must have fried the driver circuitry when I soldered my display. Does anyone know how easy this is to do...
I'll be more careful next time :-p |
nebula_1979
Plot XY and scroll functions |
Posted: Sun Jul 30, 2006 1:59 am |
Hi.
Does anyone implement a PlotXY, PlotLine functions or scroll functions?
Regards |
joven
Joined: 30 Jan 2007 Posts: 56 Location: Viana do Castelo - Portugal
Posted: Sat May 12, 2007 3:47 pm |
Hi
Does anyone implement with this driver a function can give the coordinates and print a dot, any place of the LCD.
Thanks |
zola
solution |
Posted: Mon Jun 11, 2007 12:46 am |
Use FastLCD, remember that the display have 84x48 pixel, make this change in FastLCD, after that draw a picture. Press BAS button, clic image, you whil be prompted to save the file, save it but whit .txt at end.
Open word copy paste the code, clic replace , replace &h whit 0x . In this momment you have an 504 array. You must split it in 2 tables 240 and another one smaller 24 i think.
EX:
BYTE const picture1[240]={
........ //whitout ","
BYTE const picture2[240]={
BYTE const picture3[24]={
save this file in my_picture.c . After that add in your code:
#include <c:\....\my_picture.c>
void picture_1 (void);
void picture_1(void){
nokia_clear_screen();
for(i=0;i<240;i++){
nokia_write_data(picture1[i]);
for(i=0;i<240;i++){
nokia_write_data(picture2[i]);
for(i=0;i<24;i++){
nokia_write_data(picture3[i]);
main(){
//your code
picture_1();//clear the screen and print the image!!!
Allsow you can write your picture in an 24cxxx but you must changhe the function to read from eeprom. ;)
Best Regard
Nicola Bogdan |
buneri
Posted: Mon Oct 08, 2007 1:46 am |
I wanna work on Mobile Communication but i have Nokia6030
Is the above code will work for Nokia6030 and other Nokia mobile?
Plz reply!
Thanks |
zola
Posted: Tue Oct 16, 2007 1:40 pm |
If you have the driver, yes it works, but the driver must have the function like the driver from 3310 display(write data). If not.... try to make some test !!! All the code I wrote work 100% for 3310, If you allready have the display try it. Just take an look at the maximum number of bytes that you can send to it, and split it.... and how the image must be converted ... AND, OR....
God Luck!!!
If someone need 2 projects : an digital weight scale (alphanumerical display) and an alarm made whit nokia 3310 display just email me, is all free (Open source!!!!). |
ROBOTICAR
Posted: Sat Nov 24, 2007 8:17 am |
thankyou......but how can I simulate " 3310 " in proteus.
Do you have any library about it? |
Valmirez
Hectorpkmn
Posted: Sat Jan 28, 2012 11:17 am |
Someone could tell me if this library have the option to print in inverse video? |
Blambik
Posted: Wed Feb 22, 2012 3:38 am |
Hectorpkmn wrote: | Someone could tell me if this library have the option to print in inverse video? |
Normal Mode: nokia_write_command(0x0c); //Normal Mode
Inverse mode: nokia_write_command(0x0D); // Inverse Mode |
