Tom Jetland
Having to Cast a pointer for 8 bits?? |
Posted: Wed Aug 31, 2011 11:01 am |
Hi.
18F4620
V4.124
I'm accessing stored data in ROM using a pointer and the
Code: | rom int8 scale[69]= { 0x45,0x5A ... }; etc. |
method of storing in ROM (Program Memory).
I'm passing the pointer address to a function as follows :-
Code: | void draw_sprite (rom int8 * sprite_ptr); |
and copying the data at the location of the pointer to an int8 variable called gfx_data as follows:-
Code: | gfx_data = *sprite_ptr; |
This worked in version V4.099 (old I know!)
but now I have to change the code to...
Code: | gfx_data = (int8)*sprite_ptr; |
to get it to work (if not, the next address after gfx_data is overwritten!)
is this part of the change made to suit ANSI as in the readme file? i.e.
Code: | Users that have old code with expresions of the form:
*(&data + i)
need to change them to:
*((int8 *)(&data) + i)
A compiler change was made to be ANSI compliant. |
Thanks,
Tom
Posted: Wed Aug 31, 2011 12:10 pm |
I got the same thing. I made a test program for you. I found the failure
starts at vs. 4.122 and continues through vs. 4.124. The compiler is
treating it as a word pointer. I even tried casting it to (rom int8 *) in
various places and it didn't help. You should email a bug report to CCS
support. I tested this in MPLAB simulator and put a breakpoint on the
delay_cycles(1) line, and looked at gfx_data and temp in a watch window.
#include <18F4620.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
rom int8 scale[6]= {0x45,0x5A,0x41,0x42,0x43,0x44};
void draw_sprite (rom int8 *sprite_ptr)
int8 gfx_data;
int8 temp;
gfx_data = 0;
temp = 0;
delay_cycles(1);
draw_sprite(scale);
