#USE RS232 issue defining STREAM - V4.120
uslimey
PostPosted: Wed Aug 31, 2011 10:32 am     Reply with quote
Apparently you are supposed to be able to specify a stream id with the #use rs232 compiler directive.
Having multiple streams with a single uart is usefull because it provides a method of changing partity at run time... you simply select the appropriate stream with putc, getc, etc.
I get a compiler error when I add STREAM=1 to the use RS232 statement
USE parameter value is out of range "STREAM"
Any ideas?
PostPosted: Wed Aug 31, 2011 11:12 am     Reply with quote
Don't use integers. It has to be a symbolic name. You don't need to
have a separate #define statement for it. Just put the identifier in
the #use rs232() statement as shown below:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=STREAM1)
You can use any name. It doesn't have to be "Stream something".
