cap110874
Trying to fprint an int16 with 18 characters |
Posted: Wed Aug 31, 2011 2:42 pm |
Hi Folks - Please bear with me if this sounds a bit stupid -
I am trying to print an int16 with 18 characters.
ie:
int16 PT_IR_pulse_pattern_up = 0b1110100100010110;
I want it to look exactly the same when it fprints to my rs232 terminal but I have tried nearly every combination of %x, %ld ect ect ect and it always comes out different.
This is what i am currently trying:
fprintf(COM_A, "%lx \r\n", PT_IR_pulse_pattern_up);
and in the RS232 terminal it is showing as:
e916
ANY wise words of advice as to where I am going wrong would be greatly appreciated |
newguy
Posted: Wed Aug 31, 2011 2:52 pm |
Code: | signed int8 i;
printf(COM_A, "0b");
for (i = 15; i >= 0; i--) {
if (bit_test(PT_IR_pulse_pattern_up, i)) {
printf(COM_A, "1");
else {
printf(COM_A, "0");
printf(COM_A, " \r\n"); |
Edit: Thanks TTelmah, bonehead mistake fixed.
Posted: Thu Sep 01, 2011 2:46 am |
Ongoing to this:
1) The key point is that the standard printf function does not provide a '%b' output, which is why you couldn't find a way of doing it directly. It is a rare output now, with hex being much more common, because of it's bulk.
2) Newguy's code shows a simple but quite efficient way of doing it, but as written, the 'wrong way round' - counter needs to go from 15 to 0, not 0 to 15.
3) A search online, will find dozens of other routes, varying in speed, and code size.
As an alternative, the internal function itoa (part of stdlib.h), can canvert a value to it's binary string representation directly.
Another 'natty' route, is a simple lookup table, based upon hex:
char hex_bin[16][5] = {"0000","0001","0010","0011","0100","0101","0110","0111", \
"1000","1001","1010","1011","1100","1101","1110","1111"};
void ophex_bin(int8 digit) {
if (digit>'9') {
if (digit>'F') digit-=0x20;
digit-=55;
else digit-='0';
fprintf(COM_A,"%s",&hex_bin[digit][0]);
fprintf(COM_A,"0b");
printf(ophex_bin,"%04lx",PT_IR_pulse_pattern_up);
fprintf(COM_A,"\n\r");
Which converts the individual hex digits, to four character text representations (adds the '0b' text as well).
There are about as many solutions to this, as days in a year!....
