Slave SPI Inhibits SCK
uN_Eof
Location: I live in Spain, with the toros, paella and tortilla
PostPosted: Tue Aug 30, 2011 5:12 am     Reply with quote
Hello all. I'm having a problem, when I configure SPI as a slave in a PIC18F4620 the PIC inhibits the clock signal coming from the master. SCK is always 0, and I don't know why.
Here is a piece of my code, if it helps.
void dsconf(){
   input(DSATT);
   input(DSCMD);
   input(DSCLK);
   setup_spi(SPI_SLAVE);
   setup_spi(SPI_H_TO_L);
   setup_spi(SPI_XMIT_L_TO_H);
   enable_interrupts(INT_SSP);
ack(unsigned int us){
   output_low(DSACK);
   delay_us(us);
   input(DSACK);
void write(unsigned int data, int doack=1){
   spi_write(data);
   if(doack)
      ack(12);
#INT_SSP
void ssp_isr(){
   command = spi_read();      //IMPORTANT STUFF
   if(command == 0x01){
      bytecount = 0;
      output_high(green_led);
   bytecount++;            //INCREMENT BYTE COUNT
   switch (bytecount){
      case 1:
         if(digital)
            //write(0x41);
            write(0xFE,1);
         if(analog)
            write(0x79,1);
         if(config)
            write(0xFF,1);
      case 2:
         if(command == 0x42){
            config = 0;
            write(0x5A,1);
         if(command == 0xFF){
            config = 1;
            write(0x5A,1);
         write(0x5A,1);
      case 3:
         if(config == 0 && command == 0x00){
            write(0xBD,1);
      case 4:
            write(0xFF,0);
         if(digital && !config)
            bytecount = 0;
      case 5:
         if(command == 0x00 && analog && !config){
            write(rxjoy);
      case 6:
            write(ryjoy);
      case 7:
            write(lxjoy);
      case 8:
            write(lyjoy);
      case 9:
         if(rtstat){
            write(0xFF);
         } else {
            write(0x00);
      case 10:
         if(ltstat){
            write(0xFF);
         } else {
            write(0x00);
      case 11:
         if(upstat){
            write(0xFF);
         } else {
            write(0x00);
      case 12:
         if(dwnstat){
            write(0xFF);
         } else {
            write(0x00);
      case 13:
         if(tristat){
            write(0xFF);
         } else {
            write(0x00);
      case 14:
         if(circstat){
            write(0xFF);
         } else {
            write(0x00);
      case 15:
         if(sqrstat){
            write(0xFF);
         } else {
            write(0x00);
      case 16:
         if(xstat){
            write(0xFF);
         } else {
            write(0x00);
      case 17:
         if(l1stat){
            write(0xFF);
         } else {
            write(0x00);
      case 18:
         if(r1stat){
            write(0xFF);
         } else {
            write(0x00);
      case 19:
         if(l2stat){
            write(0xFF);
         } else {
            write(0x00);
      case 20:
         if(r2stat){
            write(0xFF);
         } else {
            write(0x00);
Thanks in advance.
Some additional info: I'm trying to emulate a PS2 controller, and I'm connecting my emulator (slave) to a PS2 to PS3 usb controller adaptor, but the same thing happens if I connect the slave to an actual PS2.
RF_Developer
PostPosted: Tue Aug 30, 2011 6:11 am     Reply with quote
I'm pretty sure setup_spi() doesn't work incrementally. In your code only the values in the last setup_spi will have any effect. Instead you have to or the values together in one setup_spi:
setup_spi(SPI_SLAVE | SPI_H_TO_L | SPI_XMIT_L_TO_H);
That might help.
RF Developer
uN_Eof
PostPosted: Tue Aug 30, 2011 6:14 am     Reply with quote
That might help.
RF Developer
THANKS! Thank you so much... that seems to solve my problem... nobody knows how much I hate this kind of idiotic errors.... haha
