Timer miss counting
javi.ar
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Timer miss counting
PostPosted: Mon Aug 29, 2011 11:54 am     Reply with quote
Hi , I am trying to count cycles with timer0 (8 bits) in 18f4550. CCS Ver 4.108.
It should interrupt every 51.2us and in 1 second I should count someting aroung 20K. But after I delay 1sec I only count 3000. What could be wrong? I was reading about, corrected some lines , but no effect so far. Thanks a lot, here is the code.
#include <18F4550.h>
#device adc=8
#FUSES NOWDT                     //No Watch Dog Timer
#FUSES WDT128                    //Watch Dog Timer uses 1:128 Postscale
#FUSES HSPLL                     //High Speed Crystal/Resonator with PLL enabled
#FUSES NOPROTECT                 //Code not protected from reading
#FUSES NOBROWNOUT                //No brownout reset
#FUSES BORV20                    //Brownout reset at 2.0V
#FUSES PUT                       //Power Up Timer
#FUSES NOCPD                     //No EE protection
#FUSES STVREN                    //Stack full/underflow will cause reset
#FUSES NODEBUG                   //No Debug mode for ICD
#FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                     //Program memory not write protected
#FUSES NOWRTD                    //Data EEPROM not write protected
#FUSES IESO                      //Internal External Switch Over mode enabled
#FUSES FCMEN                     //Fail-safe clock monitor enabled
#FUSES NOPBADEN                  //PORTB pins are configured as digital I/O on RESET
#FUSES NOWRTC                    //configuration not registers write protected
#FUSES NOWRTB                    //Boot block not write protected
#FUSES NOEBTR                    //Memory not protected from table reads
#FUSES NOEBTRB                   //Boot block not protected from table reads
#FUSES NOCPB                     //No Boot Block code protection
#FUSES NOMCLR                    //Master Clear pin used for I/O
#FUSES LPT1OSC                   //Timer1 configured for low-power operation
#FUSES NOXINST                   //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL12                     //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4                   //System Clock by 4
#FUSES USBDIV                    //USB clock source comes from PLL divide by 2
#FUSES VREGEN                    //USB voltage regulator enabled
#FUSES ICPRT                     //ICPRT enabled
#use delay(crystal=20000000,  clock=5000000)
#include <velocidad.h>
// Definicion de DEBUG.
#define DEBUG
//#define USB
#ZERO_RAM
#id CHECKSUM
#define MAX_TIMER_COUNT 0xFF     // Si el timer es de 16bits 0xFFFF
#define LED PIN_C2
// Definicion de los registros de calculo
unsigned int16 contador_tmr_int =0;
unsigned long time1 =0;
unsigned long time2 =0;
unsigned int velocidad =0;
#int_TIMER0
void  TIMER0_isr(void)
   contador_tmr_int++;
// Definiciones de Pines del LCD
#define LCD_ENABLE_PIN PIN_D2
#define LCD_RS_PIN PIN_D0
#define LCD_RW_PIN PIN_D1
#include <lcd.c>
#include <funciones.h>
   lcd_init();                   //Inicializo el LCD
   setup_adc(ADC_CLOCK_DIV_2);
   //setup_psp(PMP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   //setup_wdt(WDT_ON);
   //setup_timer_0(RTCC_INTERNAL); // 16 bits
   setup_timer_0(RTCC_INTERNAL|RTCC_8_bit);  // RES .2us OVRFLW 51.2us
   //setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); // RES .2us OVRFLW 13.1us - 3.6 m/s -> km/h
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); // RES 1.6us OVRFLW 104ms - 0.28 km/h -> m/s
   setup_ccp1(CCP_OFF);
   while (TRUE) {
   contador ();
   delay_ms (1000);
   output_toggle (LED);
long contador (void){
   int16 total,loc_copy;
      //disable_interrupts(INT_TIMER0);
      loc_copy = contador_tmr_int;
#ifdef DEBUG
printf (lcd_putc, "\nO %Lu ",loc_copy);
#endif
      // Inicializo el contador de interrupciones.
      //enable_interrupts(INT_TIMER0);
   return total;
Thanks in advance
PostPosted: Mon Aug 29, 2011 12:04 pm     Reply with quote
#FUSES CPUDIV4
What is the frequency of the external crystal or oscillator that you have connected to the PIC ?
Is it a crystal, or is it an oscillator ?
What frequency do you want PIC to run at ?
PostPosted: Mon Aug 29, 2011 12:43 pm     Reply with quote
my very quick calc says:
for "RES 1.6us OVRFLW 104ms"
on timer one
you would use a 2.5MHZ ext clock or rock
and NO PLL to make that timer math work out
how did you come to expect those params with a 20mhz clock
and a PLL multiplier no less ??????
javi.ar
PostPosted: Mon Aug 29, 2011 2:20 pm     Reply with quote
Well those math came out from the PIC wizard.
I have a 20Mhz crystal attached and I want to use the config for USB output.
So I have no limits for clock speed as long as I know the overflow/interrupt timing and USB working full speed.
Thanks a lot.
PostPosted: Mon Aug 29, 2011 2:30 pm     Reply with quote
These are the fuse settings for a 20 MHz crystal, with the PLL, to give
a CPU clock of 48 MHz. These fuses will also work with the USB module.
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48M)
   output_high(PIN_B0);
   output_low(PIN_B0);
javi.ar
PostPosted: Mon Aug 29, 2011 2:41 pm     Reply with quote
Ok thanks a lot for the reply, I will give a try right now, and let you know. Thanks as usual for the invaluable support.
javi.ar
PostPosted: Mon Aug 29, 2011 4:43 pm     Reply with quote
Yes, now the readings are as predicted. Thanks again. I should keep on reading.
