Frequency/Time period measurement with PIC16F917.
assimhussain
PostPosted: Fri Aug 05, 2011 7:25 am     Reply with quote
Hi. I am trying make a closed loop speed controller system. I'm struggling to measure the frequency/time period from optical encoder.
I tried to measure the time period using CCP1.
This program given below, I found it from some book.
How could I know the value at CCP_1. I tried to use it with debugger. But the value at CCP_1 keeps on changing for same period waveform.
#include <16f917.h>
#device ADC=8
#int_ccp1
void isr_ccp1()
   set_timer1(0);
   clear_interrupt(INT_CCP1);
setup_timer_1(T1_INTERNAL);
get=get_timer1();
setup_ccp1(CCP_CAPTURE_FE);
enable_interrupts(INT_CCP1);
Could anyone please give me a code to find the frequency.
I am using a PIC16F917 Microcontroller.
The crystal on demo board is a 32.768 KHz crystal.
thanks
PostPosted: Fri Aug 05, 2011 1:31 pm     Reply with quote
What's the manufacturer and model number of the demo board ?
Post a link to the web page for the board.
#include <16f917.h>
#device ADC=8
Where is your #fuses line ? It should be the next line after the #include.
What is your CCS compiler version ?
What are the voltage levels (low and high) of the input signal to the PIC ?
What is the frequency of the input signal ?
Read these threads on measuring frequency with the PIC by using
the CCP module in Capture mode, using CCP interrupts.
http://www.ccsinfo.com/forum/viewtopic.php?t=33153
http://www.ccsinfo.com/forum/viewtopic.php?t=29963
If you have any questions about that code, ask it here in this thread.
Do not post a question in those threads.
assimhussain
PostPosted: Mon Aug 08, 2011 6:36 am     Reply with quote
Hi. Thanks for your reply.
I use Mechatronics PICDEM Demo board
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023837
I really don't know about the Fuse line. I am just a beginner in this field.
CCS PCM C Compiler Version 4.038, 58276
Voltage levels:
Low - 0 Volt (approx)
High - 5 volt (approx)
Frequency of the Input signal varies. The signal is the waveform from a optical encoder which is used as as speed sensor. So the frequency varies according to the speed. I check the waveform with a oscilloscope. It varies from 17 Hz to 300 Hz. I need to detect the change in frequency to implement the control function.
Assim
Husqvarna UK
assimhussain
PostPosted: Mon Aug 08, 2011 7:22 am     Reply with quote
I tried your program on this topic..
http://www.ccsinfo.com/forum/viewtopic.php?t=41877&highlight=guitar
Could you please tell me which all connections need to be made (LCD n other) to run the program succesfully. I have never used LCD in a program before.
thanks
PostPosted: Mon Aug 08, 2011 2:30 pm     Reply with quote
What frequency is the encoder supposed to produce, in normal operation ?
It calls the count() function. If you look at the example, it shows that
the input signal pin must be given to the count() function as a parameter.
You need to look at the schematic of your Mechatronics board and decide
what PIC pin is to be used to measure the encoder frequency. Then put
that pin into the Count() function, as shown in the example program.
With regard to the LCD, use the CCS forum's search page to search for
Mechatronics LCD. Set it to "Search for all terms". You will find a sample
program.
assimhussain
PostPosted: Tue Aug 09, 2011 4:28 am     Reply with quote
At normal operation the encoder waveform gives about 40-50 Hz and in my control system I planned to adjust the PWM given to motor when it goes down.
Yes. I managed to run the LCD program. Its working perfect.
for the frequency count. I tried to test your program on this thread. could you please tell me what all changes are required to run it on PIC16F917. http://www.ccsinfo.com/forum/viewtopic.php?t=41877&highlight=code+measure+frequency
PostPosted: Tue Aug 09, 2011 8:22 pm     Reply with quote
I tried to test your program on this thread. Could you please tell me what all changes are required to run it on PIC16F917 ?
Did it work ? Did you use the first program (shown for the 16F84a) ?
That's the one to use with the 16F917. It compiles without errors for
the 16F917.
assimhussain
PostPosted: Wed Aug 10, 2011 3:22 am     Reply with quote
yes its compiled without any errors... but i couldnt make the display work.. so cant say if the program is working...
assimhussain
PostPosted: Wed Aug 10, 2011 9:36 am     Reply with quote
Do I need to make any other connections that other than xmit=PIN_B1, rcv=PIN_B0, and input ?
PostPosted: Wed Aug 10, 2011 10:07 am     Reply with quote
What PIC pin are using for the input signal ?
The input pin is specified below. In the example below, I have pin B0.
What pin do you have there ? And, is your input signal actually connected
to that pin ?
result = count(PIN_B0, 1000);
printf("%lu\n\r", result);
assimhussain
PostPosted: Thu Aug 11, 2011 6:52 am     Reply with quote
I'm using pin B0 itself.
Can I ask you a different question... maybe a stupid one.
Whenever I try to use the registers in CCS directly like we do in Hi-tech complier rather than using functions it returns a error.
eg: using PORTB = 0b00000111; etc returns error 'Undefined Identifier'
how can I use the registers direcly to make changes in program.
PostPosted: Thu Aug 11, 2011 1:21 pm     Reply with quote
I used the program below with the count.c file from the other thread in
the link, and it works perfectly. This was tested with your version,
vs. 4.038. I used a BK Precision model 4011 function generator to put
out a 50 Hz squarewave with 0 to 5v voltage levels, and I connected it
to pin B0 (also the ground lead on the function generator is connected to
ground on the board). This is the output in the TeraTerm window on my PC.
It's working.
50
50
50
50
50
50
50
50
50
Here's the main program, modified for use with the 16F917:
#include <16F917.H>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT
#use delay(clock=4M)
#include "count.c"
int16 result;
// Measure the number of counts in one second
// from the input signal on Pin B0.  This will
// be the frequency (in Hz) of that signal.
   result = count(PIN_B0, 1000);   // count period = 1000 ms
   printf("%lu \n\r", result);
compiler rather than using functions it returns a error.
Use #byte statements to define the register addresses. Example:
#byte PortB = 0x06
Or
#byte PortB = getenv("SFR:PORTB")
Then you can use the PortB variable in your program, to read it or to
write to it.
But be aware, on this forum we normally don't like to look at direct
register code in a program. Only if it's necessary to do some function
that CCS doesn't support with built-in functions, or to fix a bug.
In other words, don't post a program with lots of direct register access
and ask for help. We prefer that you use the CCS functions if possible.
