		| Author | Message |
		| ihsanbu
				| hi all  help in coding using ccs c |
				|  Posted: Sun Aug 07, 2011 2:20 pm |   |
				| How can I get adc value (10BIT) using PIC18f452 mcu? Can I get desired value from sample voltages(0>>5volt) at which i decided some control action? e.g
 If adc read routine read the value 3volt dc then I want to switch ON the portc.1 and send this value to Serial port.
 thank you
		| MiniMe
				|  Posted: Sun Aug 07, 2011 4:20 pm |   |
				| Hi ihsanbu
 I believe i got just the thing your looking for.
 If it a function that inputs a ADC value ( number 0 - 1023, 2^10 bit ) and output (returns) a voltage varuble that is equal* to ADC value.
 This function do use ADC limits. Upper limit and lower limit: references - min and max. Look it up. Normal (without references) ADC assigned 10bit number to voltage 0-5V.  This function only sees* voltage values between 1,2 - 3,4V.  It is for increasing accuracy as voltages below 1,2 and 3,4 are not used.
  	  | Code: |  	  | unsigned int16 ADC2voldid(int16 adc_v22rtus)
 //Muutujate deklareerimine
 unsigned int32 voldid;
 unsigned int16 voldid_16;
 //Muutujasse "adc_v22rtus" l2heb ADC registi v22rtus
 //adc_v22rtus = adc_keskmine(0);
 //Valem, et teisendada ADC v22ruts -- > Pingeks (V)
 //100000 on ylemise ja alumise piiri vahe, antud juhul 3,4V - 1,2V = 2.2V
 voldid = (unsigned int32) (( adc_v22rtus * 220000));
 voldid_16 = (unsigned int16) ( (voldid >> 10) / 100);
 voldid_16 += 1200; // on alumine piir, antud juhul 1.2V;
 //Funktsiooni tagatis (v22rtus)
 //printf("\n\rvoldid_16 %Ld",voldid_16);
 return voldid_16;
 The ADC value in variable "int16 adc_v22rtus", you can get from read_adc( ) function. Look up "read_adc( )" from CCS help.
 So your code part should look like:
 You should put tease 2 function into loop. From function ADC2voldid you will get value that represent voltage something like int16 value 302. it should mean that its around 3 V.
  	  | Code: |  	  | while(1) {
 if( ADC2voldid( read_adc(0) ) > 300)  {   //0 means ADC pin 0.
 output_c(0b11111111); // port C all pins high
 Printf("\n\rVoltage is over 3V, exactly %Lu",ADC2voldid( read_adc(0) ); // outputs string by serial port.
 else{
 output_c(0b00000000); // port C all pins low
 I hope i understood your problem. I wish you good luck with your task.
		| ihsanbu
				| thank you |
				|  Posted: Mon Aug 08, 2011 2:11 pm |   |
				| thank you _________________
 ihsan ullah khan
 Embedded Designer Since 2003
 | You cannot post new topics in this forum You cannot reply to topics in this forum
