Alyn P.
| anyone got piezo beep beep code snippet 12f629 4 MHz clock? |
Posted: Fri Aug 05, 2011 5:34 am |
Is there anyone who could help with giving me a short beep beep code to drive a little piezo transducer- its driving me mad! I realise it will probably need a transistor amp. Any help would be gratefully received.
I have tried devising one myself, but I concede defeat, mid-tone kind of beep beep would be fantastic. I will use it for diagnostic purposes.
Thank you. _________________ Al |
Posted: Fri Aug 05, 2011 1:06 pm |
This code will produce an approximately 1 KHz tone from the piezo buzzer
on the PicDem2 Plus board. You must have jumper J9 installed (this
connects pin C2 to the piezo buzzer).
#include <16F877.H>
output_high(PIN_C2);
delay_us(500);
output_low(PIN_C2);
delay_us(500);
The transistor driver circuit for the piezo buzzer is shown in the middle-
left side of this schematic:
http://ww1.microchip.com/downloads/en/DeviceDoc/PICDEM%202%20Plus%20RoHS.pdf |
Alyn P.
Posted: Mon Aug 08, 2011 2:26 am |
Super, thank you very much. That's twice now you have helped out- a few beers for you if I could. Anyway, again its much appreciated.
Al  _________________ Al |
