18F65j50 USB
peterl
18F65j50 USB
PostPosted: Fri Aug 05, 2011 12:49 pm     Reply with quote
Hi guys,
I am trying to make PC <> PIC communication with 18F65j50, but I can't set right frequency - 48MHz. The crystal wich is connected between RA6 and RA7 is 4MHZ. This is my code:
#include "18F65J50.h"
#FUSES NOWDT
#FUSES WDT128
#FUSES H4_SW
#FUSES NODEBUG
#FUSES NOXINST
#FUSES STVREN
#FUSES NOPROTECT
#FUSES FCMEN
#FUSES IESO
#FUSES MSSPMSK7
#FUSES RESERVED
#FUSES NOCPUDIV
#FUSES PLL5
#FUSES PMPDE
#use delay(clock=48000000)
//#include <pic18_usb.h>
//#include "usb_cdc.h"
void main ()
  //usb_cdc_init();
  //usb_init();
  for(;;)
    output_high(PIN_B0);    //To see roughly what is frequency
    output_low(PIN_B0);
Led connected on PIN B0 flash too slowly. I think that frequency is still 4MHZ.
Thanks in advance.
PostPosted: Fri Aug 05, 2011 2:03 pm     Reply with quote
Post your compiler version, because there are differences in the fuses
between older versions and the current compiler version.
peterl
RE:
PostPosted: Fri Aug 05, 2011 2:21 pm     Reply with quote
My compiler version is 4.084. I reduced code to this:
#FUSES H4_SW
#FUSES NOCPUDIV
#FUSES PLL1
#use delay(clock=4M)
void main ()
  for(;;)
    output_low(PIN_B0);
The Led connected on PIN B0 is still flashing with exactly 1 second. Crystal is 4MHZ and capacitors is 20pf.
PostPosted: Fri Aug 05, 2011 2:42 pm     Reply with quote
Try this oscillator setup:
#include <18F65J50.h>
#fuses H4_SW, NOWDT
#use delay(clock=48M)
peterl
RE:
PostPosted: Fri Aug 05, 2011 11:58 pm     Reply with quote
Now interval is ~12 sec, PLL still not working.
C code:
#FUSES H4_SW
#FUSES NOWDT
void main ()
  for(;;)
    output_low(PIN_B0);
ASM code:
CCS PCH C Compiler, Version 4.084           06-Aug-11 08:52
               Filename: UPS-IARA.lst
               ROM used: 114 bytes (0%)
                         Largest free fragment is 32646
               RAM used: 6 (0%) at main() level
                         7 (0%) worst case
               Stack:    1 locations
0000:  GOTO   002C
.................... #include "18F65J50.h"
.................... //////// Standard Header file for the PIC18F65J50 device ////////////////
.................... #device PIC18F65J50
.................... #list
.................... #FUSES H4_SW
.................... #FUSES NOWDT
.................... #use delay(clock=48M)
0004:  CLRF   FEA
0006:  MOVLW  07
0008:  MOVWF  FE9
000A:  MOVF   FEF,W
000C:  BZ    002A
000E:  MOVLW  0F
0010:  MOVWF  01
0012:  CLRF   00
0014:  DECFSZ 00,F
0016:  BRA    0014
0018:  DECFSZ 01,F
001A:  BRA    0012
001C:  MOVLW  8F
001E:  MOVWF  00
0020:  DECFSZ 00,F
0022:  BRA    0020
0024:  NOP
0026:  DECFSZ FEF,F
0028:  BRA    000E
002A:  RETLW  00
.................... void main ()
002C:  CLRF   FF8
002E:  BCF    FD0.7
0030:  CLRF   FEA
0032:  CLRF   FE9
0034:  BSF    FC0.4
0036:  MOVLW  FF
0038:  MOVWF  FC1
003A:  BCF    FC0.4
003C:  BCF    FC2.6
003E:  BCF    FC2.7
0040:  BSF    FC0.4
0042:  MOVWF  FC2
0044:  BCF    FC0.4
0046:  CLRF   FD2
0048:  CLRF   FD1
....................   for(;;)
....................     output_high(PIN_B0);
004A:  BCF    F93.0
004C:  BSF    F8A.0
....................     delay_ms(1000);
004E:  MOVLW  04
0050:  MOVWF  06
0052:  MOVLW  FA
0054:  MOVWF  07
0056:  RCALL  0004
0058:  DECFSZ 06,F
005A:  BRA    0052
....................     output_low(PIN_B0);
005C:  BCF    F93.0
005E:  BCF    F8A.0
0060:  MOVLW  04
0062:  MOVWF  06
0064:  MOVLW  FA
0066:  MOVWF  07
0068:  RCALL  0004
006A:  DECFSZ 06,F
006C:  BRA    0064
006E:  BRA    004A
0070:  SLEEP
Configuration Fuses:
   Word  1: F7AE   NODEBUG NOXINST STVREN NOWDT NOPROTECT RESERVED NOCPUDIV PLL1
   Word  2: FFC5   H4_SW WDT32768 FCMEN IESO RESERVED
   Word  3: FD00   CCP2C1 MSSPMSK7 RESERVED PMPDE
PostPosted: Sat Aug 06, 2011 1:54 am     Reply with quote
I'm staying up late so I might as well do this. One more thing needs to
be done. We need to set the PLLEN bit in the OSCTUNE register.
That's the "_SW" (software) part of it. See the 3 new lines in the
program below:
#fuses H4_SW, NOWDT
#byte OSCTUNE = getenv("SFR:OSCTUNE")
#bit  PLLEN = OSCTUNE.6
PLLEN = 1;
peterl
RE:
PostPosted: Sat Aug 06, 2011 4:19 am     Reply with quote
Now it work Smile Thank you very much!
