using the 'code' button when posting code
carl
PostPosted: Fri Aug 05, 2011 4:07 am     Reply with quote
Hi all,
A simple question but very annoying because I can't do it.
How do you use the code button to format and highlight the posted code correctly?
I just can't seem to get it to work by pressing the 'code' button.
Carl
PostPosted: Fri Aug 05, 2011 4:36 am     Reply with quote
Key is that code must both start _and end_.
So you type something, then hit the 'code' button
Then type your code, and hit the code button _again_
Then carry on you your normal typing.
carl
PostPosted: Fri Aug 05, 2011 4:44 am     Reply with quote
Hi Ttelmah,
I've tried everything, and pressed that code button is so many ways - but it only ever appears at the bottom of the code.
Carl
carl
PostPosted: Fri Aug 05, 2011 4:47 am     Reply with quote
sorted it - thanks!!
You cannot have any spaces after the text.
I have changed my previous post about the ADC into the correct format.
Carl
