Marc-Andre Filion Guest
PIC 18F452 Interrupts Priority |
Posted: Fri Dec 13, 2002 9:46 am |
Hy,
Is there a way that can place my RS-232 sub-routine in the High priority vector (0x08) instead of the low priority vector (0x0018). I'm using a 18f452 with PCH 3.121.
I don't see anything that can go it right now.
thank!
Marc
___________________________
Original Post ID: 10030 |
R.J.Hamlett Guest
Re: PIC 18F452 Interrupts Priority |
Posted: Fri Dec 13, 2002 10:44 am |
:=Hy,
:=Is there a way that can place my RS-232 sub-routine in the High priority vector (0x08) instead of the low priority vector (0x0018). I'm using a 18f452 with PCH 3.121.
:= I don't see anything that can go it right now.
:=thank!
The 'key', is in the #INT definition.
If you use:
#INT_RDA FAST
void RDA_ROUTINE(void) {
//code here
The routine will be called using the high priority handler. This is documented in the 'readme' for the compiler, but not in the help.
There is however a big 'caveat'. A routine called this way, will not have the registers saved before execution. It becomes your responsibility to do this. Really, the best way, is to keep the code very simple, and perhaps use assembler, to just do the minimum data transfers needed in the routine.
Original Post ID: 10035 |
