SSP Interrupt Not Always Getting Serviced
Geps
PostPosted: Sat Jul 23, 2011 7:33 am     Reply with quote
Compiler: 4.087
I'm trying to code a master/slave I2C based system on two PIC18F4520.
Using this topic as an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=44686
I have the following code:
#include <18f4520.h>
#fuses INTRC_IO, PUT, NOMCLR, NOWDT, NOPROTECT, NOLVP
#use delay(internal=8Mhz, clock=32Mhz)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3)
#define SLAVE1_WRT_ADDR   0x12
#define SLAVE1_READ_ADDR  0x13
int8 data1, data2;
   printf("Starting!");
   i2c_start();
   i2c_write(SLAVE1_WRT_ADDR);
   delay_us(100);
   i2c_write(3);
   delay_us(100);
   i2c_write(3);
   delay_us(100);
   i2c_write(3);
   delay_us(100);
   i2c_write(3);
   delay_us(100);
   i2c_write(3);
   delay_us(100);
   i2c_stop();
   delay_ms(50);
Slave code:
#fuses INTRC_IO, NOPUT, NOMCLR, NOWDT, NOLVP
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0x12)
#define REDLED PIN_C0
#define SCL PIN_C3
int8 incoming =0;
int1 ProcessDataFlag = 0;
#INT_SSP
void ssp_interrupt() {
int8 state= 0;
   output_high(REDLED);
   state = i2c_isr_state();
   if(state < 0x80)     // Master is sending data
         incoming = i2c_read();
if(state >= 0x80)   // Master is requesting data from slave
output_low(REDLED);
void main ()
output_high(PIN_A7);
enable_interrupts(INT_SSP);
The problem I'm getting is that the interrupt isn't getting serviced on receipt of every byte - only the first two bytes.
Where am I going wrong?
Cheers,
PostPosted: Sun Jul 24, 2011 5:48 pm     Reply with quote
The following text and example code are in the CCS manual in the section
on the i2c_isr_state() function. Try adding the code shown in bold to your isr.
i2c_isr_state()
If 0x00 or 0x80 is returned, an i2C_read( ) needs to be performed to read the I2C address that was sent (it will match the address configured by #USE I2C so this value can be ignored).
Example:
#INT_SSP
void i2c_isr() {
if((state== 0 ) || (state== 0x80))
i2c_read();
I haven't tested this.
