How to set the PWM duty with the accelerometer value?
pacman91
PostPosted: Sat Jul 23, 2011 12:08 am     Reply with quote
#include<18F4520.h>
#DEVICE ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP, BROWNOUT, PUT
//#Define timer PIN_C2
#include <flex_lcd.c>
#define data_width 3
int8 AccData[data_width];
long valuex,valuey,
   int i;
   output_high(LCD_POWER);  // Turn on power to LCD
   output_low(LCD_RW);
   lcd_init();
   setup_adc(ADC_CLOCK_INTERNAL);//enables the a/d module
   //and sets the clock to internal adc clock
   setup_adc_ports(AN0_TO_AN2); //set the adc pins to analog
  output_low(PIN_C1);   // Set CCP2 output low
  output_low(PIN_C2);   // Set CCP1 output low
  setup_ccp1(CCP_PWM);  // Configure CCP1 as a PWM
  setup_ccp2(CCP_PWM);  // Configure CCP2 as a PWM
  enable_interrupts(int_timer2);
  setup_timer_2(T2_DIV_BY_16, 250, 5);  // 4 ms
   disable_interrupts(int_timer2);
   disable_interrupts(GLOBAL);
        for(i = 0; i < data_width; i++)
      set_adc_channel(i);
      delay_us(10);          //a small delay is required after setting the channel
      AccData[i] = read_adc(); //starts the conversion
      lcd_gotoxy(1,1);
      printf(lcd_putc, "x = %u  y = %u  ", AccData[0], AccData[1]);
      lcd_gotoxy(1,2);
      printf(lcd_putc, "z = %u ", AccData[2]);
      delay_ms(10);
valuex = AccData[0];
valuey = AccData[1];
#int_timer2 //  setup_timer_2(T2_DIV_BY_16, 250, 5);  // 4 ms * 5(postscale) =20ms
void ISR_Timer2()
   disable_interrupts(int_timer2); // which disable is needed in this program? teach me.
   //disable_interrupts(GLOBAL);  //
  set_pwm1_duty(valuex);    // duty cycle on pin C2
  set_pwm2_duty(valuey);    // duty cycle on pin C1
    //enable_interrupts(GLOBAL);
I just simply type this code to let you all know what i wanted to do, the program is not simulated, PWM period is 4ms, please teach me how to set to 20ms, the variable in program, valuex and valuey in the set_pwm_duty(), I just simply put, because i dun know how to set the value with the reading of the accelerometer with the short range from 126_to_142(x-axis) and also the Y-axis
I though that the program can run as I imagine, after20ms, execute interrupt, set PWM duty cycle, 0.5ms_to_2.35ms( the time of SERVO MOTOR 0_to_180 degree), but the output of RC2 and RC1 result is 4ms, doesn't have any change with the postscale.
the value read from the MMA7269Q
AXIS = Angle of SERVO MOTOR ( 0 90 180)
X = 126 134 142 ( the range of the reading from accelerometer)
0 90 180 degree
Y = 69 81 96
Z = I don't want use it.
those value is the reading from accelerometer, I wanted to set the MIN, MEDIUM, and MAX value as the 0,90,180 degree of the SERVO MOTOR. I want to control 2 servo motor( model C36R) for the X-axis and Y-axis turning with the accelerometer.
pacman91
PostPosted: Sat Jul 23, 2011 12:30 am     Reply with quote
#include<18F4520.h>
#DEVICE ADC=8
long timerx,timery,valuex,valuey;
   int i;
   output_low(LCD_RW);
   lcd_init();
output_low(PIN_B0);
output_low(PIN_B1);
           set_adc_channel(i);
      lcd_gotoxy(1,1);
      lcd_gotoxy(1,2);
     delay_ms(10);
timery= (valuey^2)/376;
timerx = (valuex^10)/794000000000000000;
#int_timer2
void ISR_Timer2()
  output_high(PIN_B0);
  delay_us(timery);
  output_high(PIN_B1);
  delay_us(timerx);
//   enable_interrupts(GLOBAL);
this code i tried before the code i shown at top, this code is pull up the PIN_B0 with the delay with calculation, but the simulation result output is totally different with my calculation, why?)
because i failed to use the delay, so i change to the SET_DUTY_PWM.
but i wanted to know what problem in this, so i shown this code to you all, so i can learned it Very Happy
