aki3wrt
Servo motor control and ADC |
Posted: Fri Jul 22, 2011 8:53 pm |
I'd like to control a servo motor with PWM using TMR1 and 2,
while PIC always observes 7 sensors with ADC.
My compiler is PCM. PIC is 16F1827.
When I drive ADC in the "while(1){}",
( ex.)
set_adc_channel(2);
delay_us(15);
ax=read_adc();
PWM signal stops after a certain time.
I'd like to make to work 7 ADC in the "while".
Do I forgot some resets?
Please tell me.
#include <16F1827.h>
#fuses INTRC_IO,CLKOUT,PUT,NOPROTECT,NOWDT,NOMCLR,BROWNOUT,NOLVP,IESO
#device ADC=8
#use delay(CLOCK=4000000)
#use rs232(BAUD=9600, XMIT=PIN_B5, RCV=PIN_B1)
long width;
#int_CCP1
void ccp1_int()
output_low(PIN_B3);
#int_CCP2
void ccp2_int()
if(CCP_1 != 0x0000)
output_high(PIN_B3);
set_timer1(0x0000);
char ax,ay,az,a_pitch,a_roll,a_yaw,thermo;
setup_oscillator(OSC_4MHZ);
setup_adc_ports(sAN2 | sAN3 | sAN0 | sAN5 | sAN6 | sAN8 | sAN10 | VSS_VDD);
setup_adc(ADC_CLOCK_DIV_32);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_ccp1(CCP_COMPARE_INT);
setup_ccp2(CCP_COMPARE_INT);
set_timer1(0x0000);
width=500;
CCP_1=width;
CCP_2=20000;
enable_interrupts(INT_CCP1);
enable_interrupts(INT_CCP2);
set_tris_a(0b00101101); //7?,6CLKout,5inputonly,4LED,3AN3(ay),2AN2(ax), 1LED,0AN0(az)
set_tris_b(0b11010110); //7AN6,6AN5 5TX 4AN8 3CCP1 2AN10(thermo) 1RX 0?
output_low(PIN_A7);;output_low(PIN_A1);output_low(PIN_A4);
output_low(PIN_B3);output_low(PIN_B0);
output_high(PIN_A4);
output_low(PIN_A4);
// set_adc_channel(2);
// delay_us(15);
// ax=read_adc();
set_adc_channel(3);
delay_us(15);
ay=read_adc();
set_adc_channel(0);
delay_us(15);
az=read_adc();
set_adc_channel(5);
delay_us(15);
a_pitch=read_adc();
set_adc_channel(6);
delay_us(15);
a_roll=read_adc();
set_adc_channel(8);
delay_us(15);
a_yaw=read_adc();
set_adc_channel(10);
delay_us(15);
thermo=read_adc();
