PIC10F220 and Sleep()
Fabri
PostPosted: Fri Jul 15, 2011 8:39 am     Reply with quote
Hi to everybody,
I can't solve problem with PIC10F220 and sleep() function. The work of circuit is quite simple. The PIC is powered by 3V battery. Every 2,38 seconds wake-up and test level of one pin. In case of low level do some beeps by buzzer.
The problem is:
Every wake-up time there's a change level of pin for 40us. This change level sound buzzer for a little time.
Does it normal ?
This is simple program
#include  <10F220.H>
#include "def220.c"
#FUSES NOWDT
#FUSES NOMCLR
#FUSES PROTECT
#FUSES IOSC8
#use delay(clock=4000000,RESTART_WDT)
#use fast_io(B)
int      codice_reset;
int      conteggio_routine_buzzer;
int      nr_beep;
int    codice_buzzer;
int16   conteggio_attesa;
int1   liquido_presente;
#define durata_beep 250
#define attesa_beep 10
//Definisci bit I/O
#bit ingresso_livello=GPIO.1
#bit buzzer=GPIO.0
#bit uscita_pwm=GPIO.2
Routine gestione buzzer
int      nr_beep;
int      durata_beep;
int      attesa_beep;
int      conteggio_durata_beep;
int      conteggio_attesa_beep;
int    codice_buzzer;
void gestione_buzzer(){
   switch (codice_buzzer){
      case 0:
      buzzer=false;
      case 1:
      conteggio_routine_buzzer=durata_beep;
      codice_buzzer=2;
      case 2:
      buzzer^=1;
      conteggio_routine_buzzer--;
      if (conteggio_routine_buzzer==0){
         codice_buzzer=3;
         conteggio_routine_buzzer=attesa_beep;
      case 3:
      buzzer=false;
      delay_ms(10);
         codice_buzzer=4;
      case 4:
      nr_beep--;
      if (nr_beep==0)
         codice_buzzer=0;
         codice_buzzer=1;
//#pragma zero_ram
long i;
SET_TRIS_B(0b00000010);
SETUP_ADC_PORTS(NO_ANALOGS);
//Definisci interrupt TIMER0 ogni 100uS
//SETUP_TIMER_0(RTCC_DIV_1|RTCC_INTERNAL|RTCC_8_BIT);
SETUP_WDT(WDT_2304MS|DISABLE_WAKEUP_ON_CHANGE|PIN_CHANGE_FROM_SLEEP);
codice_reset= RESTART_CAUSE();
   if (codice_reset==NORMAL_POWER_UP){
      for(i=0;i<50;i++){
         delay_us(50);
         buzzer^=1;
   if(codice_reset==MCLR_FROM_RUN){
      conteggio_attesa++;
      if(conteggio_attesa>3){
// PWM
         if (liquido_presente==false){
         codice_buzzer=1;
         nr_beep=3;
            while(codice_buzzer!=0){
               delay_us(100);
               gestione_buzzer();
      conteggio_attesa=0;
//buzzer=0;
//uscita_pwm=0;
SET_TRIS_B(0b00001111);
sleep();
delay_cycles(2);
Thanks for help,
Regards,
