Timer0 with PIC16F877A
Nora
PostPosted: Thu Jul 14, 2011 7:43 pm     Reply with quote
I copied this code from another thread and am unsure as to why it doesn't work.
I have read a ton of stuff on this forum and in the F877A data sheet about timer0, but I must be missing something.
The LED turns on in the "welcome" toggle.
Thanks in advance for insight.
Nora
#include <16f877A.h>
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP      // changed to HS for 20 mHz
#use delay(clock=20000000)                           // one instruction=0.2us
#include <stdlib.h>
#use standard_io(a)
#use standard_io(b)
#use standard_io(c)
// global variables
int16 count=0;
#int_TIMER0
void TIMER0_isr()
   if(count == 0)
    output_high(pin_A5);
    count++;
   set_timer0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_256); //
   output_high(PIN_A5); // Welcome
   output_low(PIN_A5);
while(1){
      if(count > 500) //
            output_low(PIN_A5);
            count = 0;
PostPosted: Thu Jul 14, 2011 9:45 pm     Reply with quote
Change 'count' to an int8, and change the test to check for 50 instead of 500.
Nora
PostPosted: Fri Jul 15, 2011 6:57 am     Reply with quote
Thanks for the reply PCM. I did as suggested and no joy.
I eventually got it to work and for completeness, am posting the solution.
Turns out I was using the wrong function (I am definitely not sleeping enough!).
From the CCS manual,
setup_timer_0(mode) Sets the source, prescale etc for timer0
set_timer0(value) or
set_rtcc(value)
Initializes the timer0 clock/counter. Value may be a 8 bit or 16 bit
depending on the device
So I changed the function
set_timer0
to
setup_timer_0
and all is well.
Nora
