Comparator doubt
xxopiumxx
Comparator doubt
PostPosted: Fri Jul 01, 2011 10:55 am     Reply with quote
Hi people, I am working in a project for timing the amount of time that takes a certain pin to go from 1 to 0. In order of do that I need to get an interrupt from the comparator in a high-to-low mode with the vref_low module set around 0.8v.
The problem is that I can't find the way of set the comparator in this high to low mode.
Does anyone know how to do this? or someone have a better way of getting what i need?
Thanks a lot and sorry for my horrible English.
PostPosted: Fri Jul 01, 2011 12:56 pm     Reply with quote
1. Post your PIC and compiler version.
2. Also, what type of signal is this ? Is it a sine wave ? What are the
high and low voltage levels of the waveform ? What's the frequency ?
If it's not a continous sinewave, then what's the shortest and the longest
risetime that you expect to get from the waveform ?
