delene
Counting number of samples |
Posted: Fri Jun 24, 2011 8:51 am |
Hi..
I am reading in 200 samples of data, and want to count which value appears the most number of times in the list.
I haven't got a clue on how to start or do this, and am hoping that someone can take pity on me and tell me how.
Delene |
delene
Posted: Fri Jun 24, 2011 8:53 am |
Just wanted to add, I can either count them as I read them or store them in an array and count them, which ever is easiest |
Posted: Fri Jun 24, 2011 9:31 am |
What is the range of values for the incoming data, i.e. what is the lowest and highest possible value? |
delene
Posted: Fri Jun 24, 2011 9:34 am |
anywhere between -19999 and + 19999 |
Posted: Fri Jun 24, 2011 9:40 am |
Counting while reading, would depend on the size of the samples. If these are int8 values, then it is easy. Just have a 256 element int8 array, set all entries to zero before you start, and when each value arrives, increment the corresponding entry (so if a value of 23 arrives increment array[23]). When finished, look for the largest value in the array.
This gets harder for an int16 array, and basically impossible for float values. You would need to specify a 'margin' between which values were deemed to be identical, or it'll probably never have two identical values.
Have a look at:
<http://discuss.joelonsoftware.com/default.asp?interview.11.352366.6>
Which gives a reasonably efficient algorithm, which needs a little tweaking....
Try searching for 'finding the mode of an array'. This is the mathematical 'name' for what you want.
delene
Posted: Fri Jun 24, 2011 9:54 am |
Thank you Ttelmah for your help and for getting back to me so quickly.
The name of the function I am looking for is particularly helpful!
Will do as you have suggested THANK YOU
![Smile](images/smiles/icon_smile.gif) |
Posted: Fri Jun 24, 2011 11:17 am |
delene wrote: | anywhere between -19999 and + 19999 | This is a very wide range for 200 samples. I mean, assuming the input signal is random there will be less than 1% chance for two samples to have the same value.
You could use the banding technique proposed by Ttelmah, i.e. choosing a margin over which values are considered to be the same. But I wonder, are you really looking for the statistical mode? The value occuring most?
In most signal processing operations it is much more common to look for the median value or the average value.
What is the input signal you are processing and what goal are you trying to achieve? |
SherpaDoug
Posted: Fri Jun 24, 2011 2:01 pm |
The probabilities depend on what the numbers represent. If they are part numbers you could easily have 1 pipe, 2 flanges, 12 bolts, and 24 washers with the washers winning out.
I think this is a problem for a "sparse array". You have a real array of 200 that indexes into a virtual array of -19999 to + 19999. Every time you get a new sample you see if it is in the array. If it is there you increment the quantity. If it is not there then you put it in and give it a quantity of 1. It is a little slow, but I don't see any other way. It may on may not be worth periodically sorting the array. _________________ The search for better is endless. Instead simply find very good and get the job done. |
