Reading 6 bits from a byte
Tom Jetland
PostPosted: Thu Jun 23, 2011 5:28 am     Reply with quote
I'm storing some 6-bit Graphics in a Const char array (in Prog memory), but to be memory efficient I'm storing it consecutively: -
    array [0]            array [1]
7 6 5 4 3 2 1 0       7 6 5 4 3 2 1 0 .....   bit numbers in array
1 0 0 1 0 1 0 1       0 0 1 0 1 1 0 1 .....   data in array
5 4 3 2 1 0 5 4       3 2 1 0 5 4 3 2 .....   bit numbers for LCD
Apart from bit scanning, is there a more efficient way of extracting the data from the array in 6 bit chunks??
I've posted my code to do this below : -
for ( r = 0 ; r < sprite_height ; r++, curs_addr += 0x28 ) {
        pix_count = 0;
        bit_out = bit_offset;                           // This is offsetting the start bit of the sprite
        cursor_position ( curs_addr );
        for (;;) {
            data_read = cursor_up[x];                    // Fetching the gfx data from the ROM
            for ( bit = 7 ; bit >= 0 ; bit--, bit_out-- ) {
                if ( bit_test ( data_read, bit ) ) bit_set ( datatosend, bit_out);
                pix_count++;
            if ( pix_count == sprite_width );
                else if ( bit_out != 0 ) continue;
                bit_out = 6;
                display_gfx ( datatosend );
                datatosend = 0;
                if (pix_count == sprite_width) break;
            x++;
            if ( pix_count == sprite_width ) break;
I'm using PIC18F4620.
Any comments/suggestions on this code would be appreciated!
asmallri
PostPosted: Thu Jun 23, 2011 7:28 am     Reply with quote
How about a different approach. This will require less shifting especially when combined with the swap instruction.
I refer to a sample as one of the 6 bit data values.
Store four samples (A,B,C,D) in three bytes as follows:
    Sample A is stored in the lower six bits of location N
    Sample B is stored in the lower six bits of location N+1
    Sample C is stored in the lower six bits of location N+2
    Sample D lower 2 bits is stored in the upper 2 bits of N
    Sample D middle 2 bits is stored in the upper 2 bits of N+1
    Sample D upper 2 bits is stored in the upper 2 bits of N+1
Regards, Andrew
PostPosted: Thu Jun 23, 2011 8:31 am     Reply with quote
Was about to post a couple of suggestions, and see Asmallri has posted half the same idea.
For an incoming 'object_number', you have:
    byte_address=object_number/4;
    val=object_number&3;
    byte_address+=byte_address*2;
    byte_address+=start_of_array;
    //Then byte_address is the address in the integer array you want to work
    //relative to, and val, determines what number to fetch
    switch (val) {
    case 0:
        val=*(byte_address) & 0x3F;
    //etc..
This gives very efficient calculation of whether you are dealing with value A,B,C or D, and calculation of the array starting byte from the object number (/4*3 - the first is done as a rotation, as is *2).
Cases, 1&2, are identical, with 1 or two byte offsets.
Case 3, would be the 'fiddliest', but even this, can be done quite efficiently, using standard instructions. Look at rotating the top two bits _right_ twice (CCS rotate_right function), then (as asmallri says) swapping the high and low nibble (swap), and or'ing the top two bits of this into place, and then rotating the top byte left by two.
Something like:
    int a,b,c;
    a=*(byte_address) & 0xC0;
    b=*(byte_address+1) & 0xC0;
    c=*(byte_address+2) & 0xC0;
    //This could be written using an array, but then increases the work later
    rotate_right(&a,1);
    rotate_right(&a,1);
    swap(b);
    rotate_left(&c,1);
    rotate_left(&c,1);
    a|=b;
    a|=c;
Tom Jetland
PostPosted: Fri Jun 24, 2011 2:23 am     Reply with quote
Thanks guys,
I'll try these methods out and see how they fit in with my application.
Thanks for the input and ideas :-)
