PWM issue
cerr
PWM issue
PostPosted: Tue Jun 14, 2011 5:14 pm     Reply with quote
Hi There,
I'm using 200kHz PWM on a 16F883@20MHz. I set the timer value to 24 in order to get 200kHz and I'm left with very few settings for the pwm (from 0% to 100%). Is there any way I can get a better resolution?
My sample code is below:
#include <16F883.h>
#device adc=10 WRITE_EEPROM=ASYNC
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES BROWNOUT               //No brownout reset
#FUSES NOIESO                     //Internal External Switch Over mode enabled
#FUSES BORV40                   //Brownout reset at 4.0V
   setup_timer_2(T2_DIV_BY_1,24,1);
   setup_ccp1(CCP_PWM);
   setup_ccp2(CCP_PWM);
   set_pwm1_duty(20); //80%
   set_pwm2_duty(20);  //80%
   while (1);
Thanks for hints and suggestions!!!!
Ron
PostPosted: Tue Jun 14, 2011 5:27 pm     Reply with quote
Use 10-bit PWM mode. You will get 4x the resolution of 8-bit mode.
To enable 10-bit mode, use a 'long' (int16) value for the duty cycle.
For a constant, the easy way to declare it as a 'long' is to put an 'L'
on the end. Try the following and look at your scope to see what happens:
set_pwm1_duty(20L);
cerr
PostPosted: Tue Jun 14, 2011 6:11 pm     Reply with quote
NICE! Yes, exactly! Cool, thanks! Smile I read something in the docu about that, and tried e.g. 0x001 and thought it would be represented as a 12bit number but i needed a long to make it work. Thanks!!!
pacman91
PostPosted: Mon Jun 20, 2011 6:37 pm     Reply with quote
set_pwm1_duty(20L);
Sir, the 4x resolution mean if want to get 80% of 24 = 20, in 10bit mode need to times with 4, 20*4=80, not like this? last time i saw other code with times 4, if i wrong please tell me what is wrong, i newbie
set_pwm1_duty(80L);
cerr
PostPosted: Mon Jun 20, 2011 8:32 pm     Reply with quote
I think
set_pwm1_duty(80L);
should do what you anticipate.
