		| Author | Message |
		| JakobDM
				| Using Hardware i2c as slave and a software i2c as Master |
				|  Posted: Wed Jun 15, 2011 1:27 pm |   |
				| Hi
 In a current project I need to be communicating to a few devices via i2c, but my PIC18F2455 is already a i2c slave.
 The documentation mentions for i2c FORCE_SW.  Is it possible to do the following:
  	  | Code: |  	  | #use I2C(slave,sda=PIN_B0,scl=PIN_B1, FORCE_HW)
 #use I2C(master,sda=PIN_B5,scl=PIN_B6, FORCE_SW)
 Would you need to write any code in order to make the master part work?
 Best regards
 Jakob
		| PCM programmer
				|  Posted: Wed Jun 15, 2011 2:01 pm |   |
				| You should add the stream parameter to each one and give each stream a unique name.  Then use the stream ID in i2c_start(),
 i2c_write(), i2c_read(), i2c_stop(), etc.
 Also, you are using the debugger's clock pin (Pin B6) for the Master,
 so don't expect to be able to debug the program with your ICD.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
