Using Timer1 as external pulse counter
Phygraff
PostPosted: Tue Apr 26, 2011 7:14 pm     Reply with quote
I'm trying to use the timer1 feature of PIC18F2550 as a counter of external pulses (from a rotary encoder), but I'm not familiar with C programming. Anyone can help me with the basics?
Thanks.
Luis A. Torres
PostPosted: Wed Apr 27, 2011 12:10 pm     Reply with quote
CCS only has one example for using Timer1 as an counter with an
external clock source. I don't like, it's very messy:
c:\program files\picc\examples\ex_freqc.c
I don't have time today to write a more clean example. I have always
avoided using Timer1 in that mode, because there's an errata on it.
They have a work-around in the errata, but again, it would take me
some time to incorporate the errata and make a nice clean example
and I don't have time today.
ze.vana
PostPosted: Sun Jun 12, 2011 4:47 am     Reply with quote
Hi
I've done this simple code using timer0 timer1 with external inputs T0CKI RA4/T1CKI RC0. I'm sure you it works, only problem it needs external circuit
to detect pulses A/B direction, I have Proteus photo diagram, don't know how to post it.
#include <18F452.h>
#include <lcd.c>
int16  T0,T1;
float R;         //R is the result of Timer1 - Timer0
                 //I had to put a FLOAT insted INT16
void print_lcd(){ //because of LCD did not work well whith INT16,
  lcd_init();     //I don't know why!
  lcd_gotoxy(1,1);
  printf(lcd_putc,"\f%g" R);
  delay_ms(200);
 void print_serial() {
   t1=GET_TIMER1(); //get counter UP value
   t0=GET_TIMER0(); //get counter DOWN value
   R=T1-T0;         //R is the actual encoder value
   printf("\f R:%g T1:%Lu T0:%Lu  ",R,T1,t0 );
   delay_ms(200);
   if(t0 > t1){ //prevent to not anti-clokwise first
   SET_TIMER0(0);
   SET_TIMER1(0);
#int_timer2
void timer_t2(){
static int tmp;
tmp++;
if(tmp <=5){ //it divides the timing of showing
print_lcd(); //LCD and serial
if(tmp>=5){
print_serial();
if(tmp>=10){
tmp=0;
void main(){
set_tris_a(0xff);
set_tris_b(0xff);
set_tris_c(0xff);
set_tris_d(0xff);
//TIMER0 16 bits as counter /DOWN- ext input  T0CKI RA4
 SETUP_TIMER_0(RTCC_EXT_H_TO_L|RTCC_DIV_1);
 SET_TIMER0(0);
      ENABLE_INTERRUPTS ( INT_TIMER0 );
      ENABLE_INTERRUPTS ( GLOBAL );
// TIMER1 16 bits as counter /UP- ext input  T1CKI RC0
 SETUP_TIMER_1(T1_EXTERNAL | T1_DIV_BY_1 );
 ext_int_edge(H_TO_L);
 set_timer1(0);
      enable_interrupts(int_timer1);
      enable_interrupts(global);
//TIMER2 int
 SETUP_TIMER_2(T2_DIV_BY_1,0xc0,2);
 set_timer2(0);
      enable_interrupts(int_timer2);
while(true){
