Can Mask?
DougW
Can Mask?
PostPosted: Wed Jun 08, 2011 11:53 am     Reply with quote
Can someone show me the correct format to create a Mask and filter mask for an ID 1819 ? I have read the forum, datasheet, example file and driver but just need to see what it should be then I can go from there.
I have tried many combinations from 0x0000 to FFFF but 2 different messages get through with an ID of 1090 & 1819 just want to see 1819.
   can_set_id(&C1RXM0,1819,false);
   can_set_id(&C1RXF0,1819,false);
   can_set_id(&C1RXF1,1819,false);
Thanks Doug W
DougW
Got it
PostPosted: Wed Jun 08, 2011 12:56 pm     Reply with quote
FYI need to add the can set mode and can set mode normal line.
This is for a DSPic30F6012A.
int32 Can_ID=1819;
can_set_mode(CAN_OP_CONFIG);
can_set_id(&C1RXM0,Can_ID,0);//1819
can_set_id(&C1RXM1,Can_ID,0);
can_set_id(&C1RXF0,Can_ID,0);
can_set_id(&C1RXF1,Can_ID,0);
can_set_id(&C1RXF2,Can_ID,0);
can_set_id(&C1RXF3,Can_ID,0);
can_set_id(&C1RXF4,Can_ID,0);
can_set_id(&C1RXF5,Can_ID,0);
can_set_mode(CAN_OP_NORMAL);
