Doubt in the definition of a function
pilar
PostPosted: Wed Jun 08, 2011 4:21 pm     Reply with quote
Hi, someone can tell me what my error in the Sample definition of this function?
#include <18F452.H>
#fuses HS, NOWDT, BROWNOUT, PUT, NOLVP
#define DAQ0   PIN_C0
void Reset(int DX ){
   output_low(DX);
   delay_us(500);
   output_float(DX);
   delay_us(500);
void main(){
while (1){
   Reset(DAQ0);
PostPosted: Wed Jun 08, 2011 4:49 pm     Reply with quote
#define DAQ0 PIN_C0
Look in 18F452.h and see the number value for PIN_C0.
Then look at the size of the parameter that you put in the function
declaration:
An 'int' in CCS is an unsigned 8-bit integer. It can only hold 0 to 255.
You need to edit the function declaration and fix it.
