assaad
AD7705 reading problems |
Posted: Mon Jun 06, 2011 9:35 am |
Hello everyone
I have connected REF+ to 2.5V
REF- to gnd
AN2- to gnd
Then on AN2+ I put voltage from 0 to 2.5 that through a POT.
So when the voltage on AN2+ is 2.5v I should get a reading of 0xFFFF. But I get about 0x5555, which is it 0xffff/3
Do I have anything wrong with the connections?
My setting of ad7705 is
Code: | setup_adc_device( ADC_SELF, ADC_GAIN_1, ADC_UNIPOLAR, ADC_50);
Thank you |
Posted: Mon Jun 06, 2011 9:46 am |
Tell us a lot more.
What PIC are you using?.
What connections for DRDY, DO, DI, RESET, CS and CLK?.
You have the required crystal?.
You are initialising the lines as in adc_init, except for the change to unipolar?.
assaad
Posted: Tue Jun 07, 2011 1:16 am |
Thank you Ttelmah
The problem is solved.
Before using this setup, I should choose the correct channel in the communication register.
setup_adc_device( ADC_SELF, ADC_GAIN_1, ADC_UNIPOLAR, ADC_50); |
:D |
