PIC18F45K22 ADC config problem
vasiliok
PostPosted: Sat Jun 04, 2011 2:23 am     Reply with quote
Hi all!
I HAD a problem working with ADC.
Using version 4.120 of PCWHD.
Here is the code that is NOT working.
Compilator gives no error, ADC just not working:
setup_adc_ports(sAN18);
setup_adc(ADC_CLOCK_DIV_16|ADC_TAD_MUL_2);
while(TRUE){
value_adc = read_adc();
delay_us(40);
Then I RTFM :-) and wrote such a code for manual ADC configuration:
   #byte ANSELA = 0xf38
   #byte ANSELB = 0xf39
   #byte ANSELC = 0xf3a
   #byte ANSELD = 0xf3b
   #byte ANSELE = 0xf3c
   #byte ADCON0 = 0xfc2
   #byte ADCON1 = 0xfc1
   #byte ADCON2 = 0xfc0
   ANSELC = 0b11110000; // c4 c5 c6 c7
   ANSELD = 0b00001000; // d3
   ADCON0 = 0b01001011; // sAN18, ADC=ON, Start conversion!
   ADCON2 = 0b10001101 ; // Right Justify, 2 TAD,  Fosc/16
  while(TRUE){
  delay_us(40);
And this one is working perfectly!!!
What am I doing wrong? Or is it compilator config problem?
PostPosted: Sun Jun 05, 2011 3:30 pm     Reply with quote
I didn't have to do all the things you did to make it work. I only had to fix
the routine for set_adc_channel(). I replaced it with the macro shown
below. Now it works.
I connected the center tap of 5K trimpot (with each end connected to +5v
and GND) to pin C6 on the 18F45K22. I turned the trimpot from one from
end to other slowly, and I got this output, which is correct:
00 00 12 27 3f 53 60 72 80 ac dc ff ff ff
#include <18F45K22.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=16M)
#use rs232(baud=9600, xmit=PIN_B1, INVERT)
#byte ADCON0 = 0xFC2
int8 temp;
#define set_adc_channel(x)  \
temp = ADCON0 & 0x03;  \
temp |= (x << 2); \
ADCON0 = temp;
int8 value_adc;
setup_adc(ADC_CLOCK_DIV_16);
set_adc_channel(18);
while(TRUE){
  printf("%x ", value_adc);
This bug with set_adc_channel() exists in versions 4.120 and 4.121.
I have emailed CCS just now with the details on this bug, so they
should fix it in the next version.
vasiliok
PostPosted: Sun Jun 05, 2011 3:58 pm     Reply with quote
Thanx for info, PCM programmer!
Interesting!
I hope the bug will be fixed.
Michu
PostPosted: Fri Mar 16, 2012 10:17 am     Reply with quote
Thanks... solved my problem with reading AN24 as well... Very Happy
