STRANGE ERROR INT_RDA on PIC24
cfernandez
PostPosted: Fri Jun 03, 2011 12:42 am     Reply with quote
We are porting our code from PIC18F8722 to PIC24HJ256GP206A and we found a big problem. When I use INT_RDA the kbhit not work.
I attach a simple program is you change
#define USE_INT FALSE
the variable PktIncoming tell me that not have more character, this is by the kbhit. But when we use change
#define USE_INT TRUE
the variable PktIncoming never change to TRUE.
Any can help me!!! Please!!!!
We are use the last version of compiler.
Thank you very much!!!
Best Regards,
#include <24HJ256GP206A.h>
#device *=16
#fuses FRC_PLL                  // Internal Fast RC oscillator with PLL
#fuses CKSFSM                   // Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG                    //JTAG disabled
#use delay( clock=80000000, type=INTERNAL, RESTART_WDT )
#use rs232(UART1,baud=115200,parity=N,bits=8,restart_wdt,errors,stream=COM1, )
#use rs232( xmit=PIN_B15, baud=115200, parity=N, bits=8, stream=DBG )
#byte U1STA = getenv("SFR:U1STA")
#bit URXDA = U1STA.0
static int8 Buffer[ 300 ];
static int16 Len=0;
static int8 PktIncoming=0;
#if USE_INT
#int_RDA
#endif
void  RDA_isr(void)
    int16   lTimeOut = 55000;
    // Read Character
    if ( Len < 300 )
        Buffer[ Len++ ] = fgetc( COM1 );
    // Wait 10ms for next character
    while ( !kbhit( COM1 ) && lTimeOut-- );
//    while ( !URXDA && lTimeOut-- );
    // Exist other character?
    PktIncoming = !kbhit( COM1 );
//    PktIncoming = !URXDA;
    int16 i;
    rs232_errors=0;
    #if USE_INT
    #endif
    while( 1 )
       #if USE_INT
            enable_interrupts(INT_RDA);
 //           delay_ms( 2000 );
       #else
            if ( kbhit( COM1 ) )
                RDA_Isr( );
       #endif
      // If not exist more character show the capture data
      if ( PKtIncoming )
            disable_interrupts(INT_RDA);
            fprintf( DBG, "Inc:%u Len:%lu :", PktIncoming, Len );
            for ( i = 0 ; i < Len ; i++ )
                fprintf( DBG, "%02X", Buffer[ i ] );
            fprintf( DBG, "\n\r" );
            PktIncoming = Len = 0;
