Problems between RFID and PIC
GabrielVinicios
PostPosted: Fri May 27, 2011 3:13 pm     Reply with quote
I bought a RFID-12 and i´ve looking for a solution to communicate it with uC PIC16F628A. I found two ways to follow:
- Using RS232 protocol;
- Using the example in the file ex_rfid.c, that exists in the folder examples.
I´ve tried to communicate it with RS232 and it doesn´t work. Look at my code:
#include "C:\Users\Thiago\Desktop\eletronica\PIC1\rfid.h"
#use rs232(baud=2400,parity=N,xmit=PIN_a2,rcv=PIN_a1,bits=8,stream=ID12)
   #define LCD_DATA_PORT getenv("SFR:PORTB")
   #define LCD_ENABLE_PIN  PIN_b0
   #define LCD_RS_PIN      PIN_b2
   #define LCD_RW_PIN      PIN_b1
   #define LCD_DATA4       PIN_B4
   #define LCD_DATA5       PIN_B5
   #define LCD_DATA6       PIN_B6
   #define LCD_DATA7       PIN_B7
   #define LCD_TYPE 2
   #include <lcd.c>
   char valor[12];
   int aux;
   char c;
   lcd_init();
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   disable_interrupts(INT_RDA);
   disable_interrupts(GLOBAL);
   output_high(pin_a7);
lcd_putc("teste...");
while(TRUE) {
 for (aux=0;aux<12;aux++){
 valor[aux]=getc();
printf (lcd_putc,"%d",valor[aux]);
delay_ms(2000);
lcd_putc("\f");
The LCD Display showed just it: -1 -1 -1 -1 -1 -1 -1
I tried also several bauds, like 9600, 2400, etc.
I found out another code in this forum, and it doesn´t work too. See:
#define RFID_START_BYTE 0x0A
#define RFID_END_BYTE   0x0D
void get_rfid_string()
int8 s[12];
unsigned int8 max=20;
  unsigned int8 len;
  char c;
  // Wait for start byte
  do
    c = fgetc(ID12);
  } while (c != RFID_START_BYTE);
  // Receive data until END byte is received or buffer full
            // correct for terminating zero
  len=0;
s=0;
  while ((c != RFID_END_BYTE) && (len < max))
    c = fgetc(ID12);
    s[len++] = c;
 // fprintf(CPU, "%s\n", s);
printf(lcd_putc,"\f%s\n",s);
//3. Main program
VOID main()
  printf(lcd_putc,"\f");
         DO {
                get_rfid_string();
            } WHILE(TRUE);
But in this case, nothing appears on the LCD.
What am I doing wrong?
I tried it with several tags...
Thank you so far.
PostPosted: Fri May 27, 2011 4:50 pm     Reply with quote
Post a list of your connections between the PIC and the ID-12. Post the
pin numbers that have the connections on them.
