Problems with function definitions
Alejandro
PostPosted: Mon May 23, 2011 4:42 pm     Reply with quote
Hi. I'm defining a function as follows, when I compile the program I not have errors,
int Modem_Wait_Rpta(char Buffer_TX,char Buffer_RX,int Nro_char) {
printf(Buffer_TX);                 // Mensaje a ser enviado al Modem
delay_ms(2000);
if (flag_RX_Modem){                // Hay datos en el UART
    sprintf(Token,Buffer_RX);      // Mensaje esperado del modem
    if(!strncmp(Buffer_Modem,Token,Nro_char))
       return 1;
       return 0;
  return 0;
but when I call the function ...
while (Modem_Wait_Rpta("AT+SBD","+SBDI:1",9));
the compiler gives me the following error
*** Error 90 "Modem_4x.c" Line 428(37,38): Attempt to create a pointer to a constant
Someone could tell me what my error and how to fix this.
PostPosted: Mon May 23, 2011 5:27 pm     Reply with quote
To fix the error message, add the #device statement shown in bold below:
#include <16F877.H>
#device PASS_STRINGS=IN_RAM
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
Also, you are passing char pointers as your function parameters. So the
parameters should be declared as char pointers, as shown below in bold.
int Modem_Wait_Rpta(char *Buffer_TX, char *Buffer_RX, int Nro_char)
