kender
USB and Crystal frequency |
Posted: Mon May 23, 2011 1:03 pm |
Colleagues,
I wrote a working code based USB HID example (fuses that set the clock are below). USB host successfully enumerates my device if it has 20MHz crystal (xtal).
Code: | #include <18F2550.h>
#device ICD = TRUE
#fuses HSPLL, NOWDT, NOPROTECT, NOLVP, NODEBUG, USBDIV, PLL5, CPUDIV1, VREGEN
#use delay(clock = 48000000)
#define USB_HID_DEVICE TRUE
How can I make it work with 12MHz crystal? If I simply install a 12MHz crystal, USB host doesn’t enumerate my device, although the rest of the firmware runs (with slower timing, of course).
I bet, this subject came up in the forum before, but I couldn’t find those threads.
Any suggestion, insight or reference is really appreciated!
Cheers,
- Nick _________________ Read the label, before opening a can of worms. |
Posted: Mon May 23, 2011 1:11 pm |
Quote: |
USB host successfully enumerates my device if it has 20MHz crystal.
#device ICD = TRUE
The PLL requires a 4 MHz input. The fuse shown in bold is the pre-scaler.
20 MHz / 5 = 4 MHz. Look in the 18F2550.h file to see other available
pre-scaler values for that fuse. |
