Modbus example not working
Sid2286
PostPosted: Mon May 23, 2011 11:36 pm     Reply with quote
I'm trying to implement Modbus protocol for quite sometime now, and not yet successful.
So, I made the connections to check if my RS485 is working.
I wrote this following program to check RS-485 connections are proper.
#include <18F452.h>
#device ADC=16
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ENABLE=PIN_C5,STREAM=PC)
#include <rs485.c>
   rs485_init();
   printf("hello world");
It is working properly. But Now, I'm trying to implement the modbus communication example, given with the complier. It is not responding.
Please help. thank you.
Sid
arunb
RE:
PostPosted: Tue May 24, 2011 1:24 am     Reply with quote
MODBUS uses 9600 baud or 19200 as a standard ??
thanks
a
PostPosted: Tue May 24, 2011 7:23 am     Reply with quote
WHICH Modbus 'standard' ??
WHICH Modbus device ???
Google ????
dyeatman
PostPosted: Tue May 24, 2011 9:48 am     Reply with quote
MODBUS is a protocol and does not have a standard speed. I currently
support systems that use MODBUS at many different speeds from 1200 up.
I don't know if you need RTU or ASCII mode.
RTU mode in the MODBUS protocol requires EVEN parity where you are
currently defaulting to odd. The full standard is at the following link. I
recommend you do some reading.
http://www.modbus.org/specs.php
Google and Forum Search are some of your best tools!!!!
Sid2286
PostPosted: Tue May 24, 2011 10:28 pm     Reply with quote
Well, I was looking forward to simply see how the example (Ex_modbus_Slave.C) provided with the compiler works.
But I wasn't getting any results. Is there anything wrong with the example?
I'm using Modbus Poll software at the PC end as my Master.
Regards,
Sid
