RESTART_TRAP_CONFLICT on PIC33FJ256GP710
icesynth
PostPosted: Wed May 11, 2011 11:53 am     Reply with quote
I am using a PIC33FJ256GP710 device and when it is sent a character on the serial port (UART2) the device will reset during the reset cause as RESTART_TRAP_CONFLICT.
The UART is set up as a stream:
#use rs232(baud=57600, UART2, RESTART_WDT, stream=PC_UART, bits=8, parity=N, stop=1)
The pic can send serial data without any issues, and the restart will not happen when the UART interrupt is not enabled, and occurs no matter what code is in the interrupt routine.
The pic is running at 40 MHz, with the PLL set up as follows:
case 40:      // FVCO = 160 MHZ
PLLFBD    = 0x0026;         // M = 40 = (38 + 2)
CLKDIV    = 0x3000;         // N1 = 2, N2 = 2, Fosc = 40MHz
Timer 2 is interrupting at a rate of 1 kHz, and Timer 3 is used for PWM outputs on OC1.
Has anyone had this issue before? And if so any suggestions?
If anyone could help with this or be greatly appreciated,
Thank you in advance Smile
Programming for the the real world.
--Chris Burchett
Sylver Technologies Inc.
PostPosted: Wed May 11, 2011 12:14 pm     Reply with quote
To avoid jumping into conclusions, you should post a complete code example, that reproduces the problem and also tell your compiler version.
A trap conflict reset is quite common and usually caused by an unhandled trap interrupt, mostly stack or address error. As discussed in previous threads, you can get more information by implementing trap interrupt handlers.
icesynth
PostPosted: Wed May 11, 2011 3:18 pm     Reply with quote
Because of a compiler directive oversight, the #int_rda2 was never being called and the default interrupt handler was being called instead.
Compiler Version 4.120
--Chris Burchett
