John Morley
| Running multiple compilers..... |
Posted: Tue May 10, 2011 11:11 am |
Hi All,
I've been working with the PCM compiler and PIC16 processors for a while now, and I'm getting ready to begin my first PIC18 project with the PCH compiler.
Currently, I'm using MPLAB with PCM, and I'd like to continue that with PCH. I'm looking for some advise on how to install PCH without disabling what I've already got working, and info on how to easily switch between compilers. Is that as simple a changing the language tool for each project?
Thanks,
John _________________ John Morley |
Posted: Tue May 10, 2011 11:34 am |
Just create a project in MPLAB for your 18F PIC by using the MPLAB
project Wizard. Then compile it. The PCH compiler will automatically
be selected.
However, it's best if you have identical versions for PCM and PCH
installed on your system. If the versions are not identical, the
Devices4.dat file will only be correct for the compiler that you
installed last.
I got tired of installing the current compiler that I was using, each
time I wanted to switch to PCM or PCH. So I now just buy maintenance
for both of them, and I have vs. 4.121 installed for both. Then I
can switch between them without having to re-install each time. |
John Morley
Posted: Tue May 10, 2011 7:21 pm |
Well, it looks like I make myself a real mess !
I tried to be clever and segregate the various compilers in the 'PICC' directory. For example, I originally had 'PICC\PCM', and then I added 'PICC\PCH'. The problem (I think?) is that the way MPLAB is set-up, all the compiler executables must be in the same place, the 'devices' directories need to be merged, etc. If not, it's a major pain to switch back and forth between PCM and PCH. Am I reading this correctly?
I wonder if I can move files around manually now, or should I un-install/re-install?
Posted: Tue May 10, 2011 7:27 pm |
Years ago, Mark came up with a scheme to edit the Registry to allow
PCM and PCH to be in different directories. Here's the 3-page thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=21884
I don't want to do this, so I buy the maintenance for both compilers
so the versions are always the same, and I can install them in the
same c:\Program Files\PICC directory.
Note to others:
If you have the IDE compiler (PCW, PCWH, PCWHD) then it's no
problem to install different versions in different directories.
This question is about installing different versions of the "command-line"
compilers (PCM, PCH, and PCB) so they work smoothly with MPLAB. |
