Need suggestions for control/variable storage structures
Sergeant82d
PostPosted: Fri May 06, 2011 5:54 am     Reply with quote
I am working on a Radio Controlled robot lawnmower - I live on a farm and have a very large yard - which I hope to eventually make autonomous. I want to be sure I make the program extensible. I have the basic functionality down (finally!), and am trying to expand my programming ability by incorporating additional features.
I am including a variety of error messages & display LEDs, for one thing, and am trying to figure out a logical hierarchy for controlling them. I will be using one or more Maxim MAX7221 SPI LED Controllers, and I plan to use one segment line from the '7221 per sub-system. I have the hardware working, no problems there, but I want to organize the control logic so it is uniform and expandable.
I am thinking about an array of structs, each made up of three other struct arrays, as follows:
#define NUMBER_OF_MOTORS      4
#define NUMBER_OF_ENGINES     3
#define NUMBER_OF_MCUS        7
struct MOTOR[ NUMBER_OF_MOTORS ] {
   temperature : 16
   speed : 16
   voltage : 8
   current : 8
   is_running : 1
   is_over_voltage : 1
   is_over_current : 1
   is_over_temperature : 1
   is_over_speed : 1
   has_CAN_comms : 1
struct ENGINE[ NUMBER_OF_ENGINES ] {
   temperature : 16
   speed : 16
//   voltage : 8
//   current : 8
   is_running : 1
//   over_voltage : 1
//   over_current : 1
   is_over_speed : 1
   has_CAN_comms : 1
struct MCU[ NUMBER_OF_MCUS ] {
   temperature : 16
   voltage : 8
   current : 8
   has_power : 1
   is_over_voltage : 1
   is_over_current : 1
   has_CAN_comms : 1
struct LOCATION[ item_location ] {   // e.g.   front_left.motor.temperature = 235
   struct MOTOR[]                    // e.g.   middle_engine.mcu.has_power = TRUE
   struct ENGINE[]                    // e.g.   master_mcu.has_CAN_comms = TRUE
   struct MCU[]                   // e.g.   right_rear.motor.speed = 1250                  // Captured pulses
typedef enum {
   rear_left,
   front_left,
   front_right,
   rear_right,
   left_engine,
   middle_engine,
   right_engine,
   master_mcu,
   engine_mcu,
   contact_sensor_mcu
   }; item_location
While this looks like it will work, it also looks like it will take up a lot of RAM. I am using an 18F46K80 and have 3.8KB, but am already using half of it. Again, not a show stopper, as I am looking for something that works, but I also would like something that makes sense.
The actual members of the structs are not important as I am certain they will change as the execution is refined, but does this look like a reasonable solution?
Thanks for your time,
Brad
